wtf is going on
Old May 26, 2002 | 09:32 AM
mtcookson's Avatar
wtf is going on
Ok, so my tranny (before the new one) made a weird grinding type noise. Opened it up, throwout bearing is broken along with the casing that the bearing sits on. Put in a used tranny but everything appears fine and i get the sound again. This is the sounds my tranny made before i got it fixed AND after i got it fixed, almost as if it's broken again. Here's the sound www.paylessfreight.com/bad tranny.mp3
the sound is made when the clutch is released and disappears when the clutch is pressed.
Does anyone know maybe if this sound now is just the throwout bearing breaking in? The clutch, throwout bearing, and pressure plate are new. I'm lost now. Any help would be appreciated. Thanks.
Old May 26, 2002 | 11:41 AM
mtcookson's Avatar
no ideas??
Old May 27, 2002 | 09:33 AM
mtcookson's Avatar
i found that the sound goes crazy when you turn to the left and move. found out it's not the throwout bearing so it has to be something inside the tranny. i guess i'm just taking it to a shop.
Old May 28, 2002 | 03:14 AM
MadMaxBrent's Avatar
CV joint?
Old May 28, 2002 | 05:07 AM
Taegost's Avatar
Originally posted by MadMaxBrent
CV joint?
That's my guess
Old May 28, 2002 | 07:21 AM
Laly's Avatar
my tranny makes a grinding noise as well unless i have the clutch pushed in. when pushed in, the car sounds quiet, otherwise a constant grinding noise. my uncle has a transmission shop, but i havent had a chance to go. maybe i might go this saturday coming up. i'll let you know what he says.
Old May 29, 2002 | 01:12 PM
mtcookson's Avatar
i don't think it's the cv joint cause it makes the sounds while not moving. It almost sounds like it's a gear in there that is spinning constantly unless the clutch is in and is loose or something. I'm going to take it to a ship today to see what they say. Hopefully it's nothing too expensive.
Old May 30, 2002 | 03:16 AM
Could be that the transmission has picked up some material from the busted bearing. Check the springs in the friction disc. Perhaps one is cracked or broken and is rattling around.
I don't know too much about the Maxima manual transmissions so I'mm assuming there setup is similiar to previous manuals I've owned.
Brent.
Old May 30, 2002 | 04:59 AM
mtcookson's Avatar
i don't think it can be that. I replaced everything inside the bellhousing. I replaced the throwout bearing, clutch, and pressure plate. I didn't get to take it in yesterday but will today because this is my last day of school before the summer and i'm going to get out early!!
Old Jun 1, 2002 | 08:34 AM
mtcookson's Avatar
ok, finally got it to the guy yesterday. he said that its some bearings inside the casing that are bad. when you have the clutch in there is nothing in there spinning therefor no sound but when the clutch is out, even in nuetral, there are gears in there spinning. so, if any of you guys have that problem, start looking for a new tranny. that sound means your bearing are bad and need to be reaplaced and when the tranny people go to replace stuff in there they usually want to replace everything making it a rebuilt tranny that will cost you around 700-900 dollars. i'm just going to go find a rebuilt for around 700 or less if i'm lucky and not screw with used anymore.
Old Jun 1, 2002 | 08:42 AM
Sudesh's Avatar
if you want a rebuilt tranny for around $700 then you should contact the people at www.phoenixhardparts.com. Completely rebuilt, 6 months warranty..completely tested.
Old Jun 1, 2002 | 08:50 AM
mtcookson's Avatar
for the maxima those are actually 895 but for that kind of warrantee and stuff that's awesome. thanks for the link!
Old Jun 1, 2002 | 08:54 AM
mtcookson's Avatar
wait a minute, that price if for the auto i think.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
