Cruise problems
Cruise problems
Ive searched for an hour and no one has the same symptoms as i do.
I turn the cruise on the light on the switch comes on, push the set button cruise comes on then goes off after a second (the green light in the gauges also comes on and goes out but doesnt flash). I know it does work cause it has worked 2 times before but i have no idea whay it would work those times and then now any help please?
when I was fixing my cruise, I found that when I had a bad cruise actuator in, the green light on the gauges would come on for a few seconds but then go off after the speed dropped about 10mph or so below what I tried to set it at
Originally posted by Damion
Craig ,
where is the main control unit and where is the relays (if there are any fo rthe cruise) mabye one of thos are bad i tested the actuator and it was fine
Craig ,
if you remove lower dash on drivers side (9 or so screws), look to the right of the steering column, gray plastic box is the door lock timer, directly behind it is a metal box that is the ASCD controller (automatic speed control device=cruise)
one relay under the hood
ok ill check that if it ever decides to stop raining out. Craig while im there ill confirm the wire harness connector to disable the DRL if you still would want to post it on your site
I will probably do it soon
Originally posted by «§»Craig B«§»
cool, I've been meaning to add that to the site, but haven't done many updates recently
Unclejunebug
Apr 2, 2016 05:42 AM
