Doesn't it say not to clean the throttle bodie in the Repair manuals?
Old May 29, 2002 | 10:07 PM
JDwyer2821's Avatar
Heres what it says "CAUTION: The TB on these models is coated with a Sludge-Resistant material designed to protect the bore and throttle plate. DO NOT attempt to clean the interior of the TB with carburetor or other spray cleaners. This TB is designed to resist sludge accumulation and cleaning may impair engine performance."
Old May 29, 2002 | 10:17 PM
mykizism's Avatar
Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
bah my car still runs good
Old May 30, 2002 | 05:24 AM
N34JZ's Avatar
Needs non-Maxima Friends
bump I wana know too
Old May 30, 2002 | 05:50 AM
MaDMaX024's Avatar
i've cleaned mine twice..once was rushed, the other was complete..i took it off the car..havent had any trouble yet, and a few monthes later, its still clean. just get the correct gasket, take it off the car (very simple), clean it completely and be happy.
Old May 30, 2002 | 06:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
if it was built to resist sludge..then why the hel1 is so much crap collecting on it?
use TB cleaner..NOT carb cleaner and you're good to go.
Old May 30, 2002 | 10:31 AM
dwapenyi's Avatar
Make sure to use TB cleaner that is safe for feul injected engines.
DW
Old May 30, 2002 | 01:51 PM
MaDMaX024's Avatar
DW
i use CARB CLEANER that says on the can "also cleans throttle bodies and intake manifolds for fuel injected engines" or something to that effect.
Old May 30, 2002 | 03:29 PM
Scott Fife's Avatar
Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
I didn't have much choice... at 194,000 miles, it had to be done... protective coating or not. BTW, if you decide to squirt the TB cleaner past the butterfly valves into the intake plenum (yes that's what I did) and you use most of the can, remember where that TB cleaner fluid goes - down the plenum to the valves. When I turned the ignition key, the valves opened, and fluid dumped into the combustion chamber. Fortunately the motor didn't start and I realized what I had done before I turned the key again. Fluid doesn't compress... duh. I had to take all the plugs out and let the motor pump that stuff out the spark plug holes, then change the oil.
Old May 30, 2002 | 04:19 PM
jp91se's Avatar
Re: Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
is that true..?
Old May 30, 2002 | 05:05 PM
dwapenyi's Avatar
I guess it's good to be safe and do what you did, but if that happened to me I probably would have still started the car. Yes, fluid does not compress, but there's still a whole bunch of air in there. The air will compensate and compress a little more. So, the engine may knock a bit at startup b/c the hotter air as a result of a bit more compression ignited the feul mix a bit early. Not too likely but possible. All cars knock a little, you just have to listen very carefully sometimes to hear it. It's not as if you completely filled the combustion chamber with incompressible fluid like what might happen if your intake swallowed some water.
DW
Old May 30, 2002 | 08:33 PM
DanNY's Avatar
Ad·min·is·tra·tor
umm..if you're pouring a gallon in there then i would say yeah fluid doesn't compress.
your car won't start right away because the engine is "flooded"..too much gas not enough air. hold the gas pedal while u crank next time and you'll fire it up.
Old May 31, 2002 | 11:50 AM
Scott Fife's Avatar
Re: Re: Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
DW
Perhaps you're assuming that I consciously exibited some cautionary behaviour. I didn't. I just turned the key expecting the ole' VG to fire up. It didn't. The motor made about one a revolution and just stopped. It couldn't compress all that TB cleaner fluid in the combustion chamber. Fortunately, the starter motor doesn't have enough torque to bend a connecting rod. If the motor had started up, the result might have been different.
Old May 31, 2002 | 11:54 AM
dwapenyi's Avatar
Re: Re: Re: Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
Yeah, I did think it was cautionary behaviour. By the way, how much fluid are we talking about that spilled into the intake?? It can't be that much. Couple of ounces?
DW
Old May 31, 2002 | 01:40 PM
Scott Fife's Avatar
Re: Re: Re: Re: Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
DW
I used up the vast majority of (what I think) was a twelve ounce can, so probably about 8 ounces went into the combustion chamber(s).
Old May 31, 2002 | 09:40 PM
jp91se's Avatar
Re: Re: Re: Re: Re: Re: Re: Doesn't it say not to clean the throttle bodie in the Repair manuals?
haha..so that's why you're supposed to leave your car facing downhill!
Old Jun 1, 2002 | 06:33 AM
dwapenyi's Avatar
Yup. Mine, too.
DW
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
Maximeltman
Aug 31, 2015 01:01 PM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
