help with E-brake handle install
Old Jun 7, 2002 | 12:06 PM
Nissan-R's Avatar
I want to install an aftermarket E-Brake handle on my 91 se. How do i go about it?? Do i cut the original handle and just put the new one over it??
I've tried to remove the plastic covering the handle, but it didn't come out easily. Is the handle seperate from the plastic covering it??
Thanxs.
Old Jun 7, 2002 | 02:10 PM
thebull's Avatar
Re: help with E-brake handle install
Thanxs.
heat it up with a hair dryer first. it should pull off
Old Jun 7, 2002 | 06:55 PM
PATRICK94SE's Avatar
I took a box cutter to mine......One of several dumb moves I have made Go with the hairdrier.....if it works
Old Jun 7, 2002 | 07:23 PM
hoodank178's Avatar
E-Brake
I just finished this mod on my 91se a week ago. The stock e-brake cover is attached pretty damn good you can try the hairdryer ( I didnt ) it might work. I had to cut the cover off with a utility knife in sections. Be sure not to cut too far down on the handle or youll have some bare metal showing at the bottom of the cover. Work slowly ( I cut the hell out of my hand doing this ). Also most of the cheap E-Brake covers wont fit without modification to the top of the handle check that the thickness of the top where the release button goes through is no thicker than an eighth to a quarter of an inch thick. I had to bore mine out to get the release button to stick out far enough to work properly.Most of the time the top cap screws on. I thought Id warn you a $10.00 Ebrake handle cost me $20.00 to have it bored out at a machine shop and a trip to the hospital for 6 stiches.
good luck
hoodank78@netscape.net
03VQMAX
Nov 10, 2015 03:39 PM
240tomax
Sep 13, 2015 03:28 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
