Only my front speakers are working and the antenna is not going up.
Old Jun 18, 2002 | 08:35 AM
Parliament's Avatar
I just got they car last night and will be putting in a Kenwood CD radio soon. But the stock radio is bugging out on me.
Is it a fuse?
Old Jun 18, 2002 | 08:58 AM
tilt's Avatar
I'm sure someone with telepathy on this board will be able to help you.
Old Jun 18, 2002 | 09:33 AM
supa's Avatar
install the kenwood then see.
same thing with mine, i changed my HU and ALL is fine.
seems the factory deck gives up after a while.
if it still fails then u got some more trouble.
jason
Old Jun 18, 2002 | 10:09 AM
maxrt's Avatar
3rd generation radio
I just installed a Nissan CD radio 1999 in my max 93 and the rear speaker was not working because the amp from the original radio is working for the front speaker and you have a seperate amp for the back speaker so you need to installed new wire from the new radio dont used the original speaker wire ,so this method had correct my problem so it's should correct yours.
Maxrt
Old Jun 25, 2002 | 06:20 AM
Parliament's Avatar
Yup I put in the Kenwood and splice the wires going into the amp to the speakers. I had two small kicker boxes in my closet and I spliced the wires to those for now. Till I get some new speakers for the back.
My wife put a freeze on the dough.Nothing for the car for a while.
Old Jun 25, 2002 | 06:53 AM
maxrt's Avatar
Freeze the Kenwood
I would like to know why you are not using the rear speaker .
What you have to do is just to pass wire from the front to the trunk and plug on the original speaker and cut the wire from the amp.
Also I'm in the same situation my wife told me the same thing on my Max to stop ( nothing for the car).
So good lock and let me know when your wife will give you GO GO GO
MaxRT
Old Jun 25, 2002 | 07:21 AM
Parliament's Avatar
Yea Yea I did that , it just the back speakers seemed blown.
I also couldnt get the bracket off the old radio, i installed the new radio right below the old one(I know it ghetto). But until I can get the bracket off the stock radio it will have to do.
A guy here at work is gonna lend me a drill with a phillips head bit on it...hopefully have that done tomorrow.
Old Jun 25, 2002 | 07:53 AM
maxrt's Avatar
Radio Bracket
When i removed my bracket on my old radio i have to drill off 4 out of 6 screws .I wish you good Lock
MaxRT
MikesChevelle
Nov 23, 2024 11:17 AM
jskirwin
Jun 8, 2016 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
