my tranny and clutch are out???
Old 06-24-2002 | 05:59 PM
gomer21's Avatar
my tranny is leaking fluid and ruined the clutch. 659$ for a used tranny at a recycling yard or 1000$ to fix my tranny and 434$ to fix clutch. this includes everything. I am a struggling college student so I have no way to afford this. Should I
1.Save the car until I can afford to repair it, then repair it 2.use the car as a tax right off by donating or 3. sell the parts and whatever else
Old 06-24-2002 | 08:27 PM
tilt's Avatar
If you are a struggling college student I dont think a tax writeoff would help at all. If you plan to sell it as is, with a good body expect ~1k for it. Maximas just dont sell well as shell cars (unlike hondas, etc). Hope this helps in your decision.
Old 06-24-2002 | 09:33 PM
Venumb's Avatar
What kind of fluid are you leaking??? Is it tranny fluid or brake/clutch fluid? If it's clutch fluid your slave (release)or master cylinder probably took a crap on you.Check your clutch fluid level..is it low? Is it empty? If that's the case, you most likely won't be needing a tranny replacement. Look into it and let me know.
Old 06-24-2002 | 10:35 PM
gomer21's Avatar
it is leaking tranny fluid I know this because the main seal is paper thin and should be 1/8 of an inch thick. I may just keep the car until after college when I can afford the fix it. 3rd generation maximas are known for weak seals and poor trannies but engines will last 300,000 miles. So rebuild the tranny and get a good clutch job and I will continue driving it after I can afford those repairs.
Old 06-24-2002 | 11:29 PM
gomer21's Avatar
Should I keep or sell my max??
I got an 89 SE that needs a rebuilt or used tranny and needs a new clutch. I love the car and would like to keep it but I just want to know if a rebuilt tranny and new clutch costing 1500$ is worth the money on my 89 SE which hasnt had nay big problems, havent modified it yet and its my first car and I dont want to let it go.
Thank you,
andrew
Old 06-24-2002 | 11:33 PM
gomer21's Avatar
can a 91 SE tranny really swap with an 89 SE??
if a 89 SE tranny swaps with a 91 SE tranny then swapping my bad 89 SE with a 91 SE tranny would be a good idea right?? because it is probably better being newer and probably has better mileage and constructed better??
please help my tranny is toast
thanks,
ANdrew
Old 06-24-2002 | 11:35 PM
Jeff92se's Avatar
I'm needing a caw
Only if the other tranny is good. If just marginal, get it rebuilt. Just because it's newer, doesn't mean it's in better condition.
Old 06-24-2002 | 11:37 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: can a 91 SE tranny really swap with an 89 SE??
yes it will work fine...either swap will work 89->91 or 91->89
thanks,
ANdrew
Old 06-24-2002 | 11:41 PM
gomer21's Avatar
which is better rebuilt tranny for 1000 dollars or used one for 650 dollars for 89 SE
rebuilt or used tranny for 89SE which is better?
Old 06-24-2002 | 11:44 PM
DA-MAX's Avatar
Re: which is better rebuilt tranny for 1000 dollars or used one for 650 dollars for 89 SE
rebuilt for $1k....simply for the obvious fact that it is REBUILT, has a warranty and all replaceable parts are new!!
Old 06-24-2002 | 11:51 PM
Jeff92se's Avatar
I'm needing a caw
Please do not make a new post each time you have a related question. Danka from your friendliest moderator at maxima.org. Have a maxima day!
hcarter1112
42
07-18-2022 04:35 PM
spencerwh1
06-30-2016 06:44 AM
fx4five
10-18-2015 07:57 PM
fx4five
10-01-2015 05:58 AM
Socalstillen
09-21-2015 12:46 AM
