Fire around coil - update
The fire around the coil seems to be from the wiring harness going to the coil (this is a VG engine). The coil and power transistor test bad using the chilton's manual test procedures. The wires to the coil and and a second 4 wire harness which appear to go nowhere along with the coil cover are burned from a flame that welded the coil cover and harness/plugs to the coil. No fuses are blown. My question is could the wires to the coil have drawn a large enough current to catch the wires on fire? Should a fuse be in this circuit to protect it? I am trying to find a junk yard where I can buy parts mostly for the plug going to the coil with enough wire to splice into harness. I am concerned that after changing these parts the new ones may fry also from a problem I maybe missing? Does anyone know if there is a 4 wire plug coming off the coil harness about 2 inches from plug that is not used on some cars (92 GXE)? Any help is appreciated.
Re: Fire around coil - update
TKHanson
11-24-2018 01:39 AM
