Camber bolts?
Old Jul 1, 2002 | 12:56 PM
nstymax93's Avatar
Camber bolts?
Which is better or are they equal the camber bolts from Eibach or from SPC performance? Also, with the SPC camber should i get the ones for 1.5 drop or a 3.0 drop, im lowered with Intrax. Also should i get the rear too? Will this help with my tire wear....My tires are shot on the inside of the tire so im guessing this is from the camber correct? Any info. is greatly appricaiated.
THANKS
-Mike
Old Jul 1, 2002 | 08:49 PM
ron4291's Avatar
Well from knowledge I have the sprint springs with ingalls
camber bolts. It is not worth the money for the camber bolts I have tried three different styles and all of them come loose on bumpy roads. Take your car to a good alignment shop and have them adjust your toe and caster front and rear. You want about +0.5 up front and
-0.4 in the rear. I now have the stocks bolts back in and no problems with play in the wheels. Of course I woulndt get this done till you get some new rubber, good luck!
Old Jul 2, 2002 | 12:01 AM
ngthing's Avatar
Re: Camber bolts?
THANKS
-Mike
SPC makes links for the rear, nobody else does (not to my knowledge).
I've got a full camer set up for front (ingalls) and rear (SPC) for sale if you are interested. Email me, jng@annulardesign.com.
Old Jul 2, 2002 | 06:12 AM
nstymax93's Avatar
So its not worth it huh? I guess i will just get new tires and get it aligned! Thanks anyways guys.
Old Jul 2, 2002 | 07:00 AM
nstymax93's Avatar
Also would getting the bolts stop tire wear on the inside of the tire or would i just need an alignment?
Old Jul 2, 2002 | 07:26 AM
ngthing's Avatar
without bolts you can't adjust the camber, so an alignment will help, but it will not stop uneven tire wear.
Old Jul 2, 2002 | 07:38 AM
nstymax93's Avatar
BUT IS IT WORTH THE MONEY GETTING THE BOLTS. RON SAID NO. WHAT DO YOU THINK NGTHING? WORTH IT OR NOT? ALSO THE BOLTS WILL HELP STOP THE UNEVEN TIRE WEAR???
Old Jul 2, 2002 | 12:14 PM
Kraus91SE's Avatar
I've had the spc for over a year and they haven't come lose. I have sprint springs and with the spc kit my chamber is correct and tires don't wear. I think I posted this more than once.
Old Jul 2, 2002 | 12:34 PM
nstymax93's Avatar
im going to get the bolts now!!
Old Jul 2, 2002 | 01:45 PM
ron4291's Avatar
Nothing why are you getting rid of your camber bolts and rear camber
set?
Old Jul 2, 2002 | 03:21 PM
ngthing's Avatar
because I'm getting rid of my car
Old Jul 2, 2002 | 04:24 PM
ron4291's Avatar
well what else do you have for sale? I need a rsb, ssbl
cross drilled rotors or 3oo zx front rotors and calipers!
let me know bud!
Old Jul 2, 2002 | 06:32 PM
John van de Pol's Avatar
My camber bolts are holding up just fine, but theu are oversized (needing a slight drillout (to 9/16") of the spindle and one of the sides of the strut). Mine are Ingalls 3542 IN. Because they are big, I can torque them up to over 100 ft/lbs, and they have stayed put so far (2 months). Some of the small wimpy ones only allow 60 ft/lbs, which is the reason they come loose.
John
Old Jul 2, 2002 | 08:50 PM
kingrye's Avatar
where can i get some SPC camber bolts please post some links
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
