93 SE to a 92 SE engine swap
Old Jul 3, 2002 | 12:36 PM
Maxima_Van_WA's Avatar
I have a totalled 1993 Maxima SE 5 speed. Is it very difficult to put the engine and tranny in a 1992 Maxime SE auto? I will have both cars side by side to do the swap, so I should have all brackets, grommets, etc. from the 1993 to put in the 1992.
Old Jul 3, 2002 | 12:45 PM
Jeff92se's Avatar
I'm needing a caw
Should be fairly straight forward since you have the ecu etc.....and in the worst case the whole 5-sp wiring harness could go over(if necessary)
Old Jul 3, 2002 | 01:20 PM
Matt93SE's Avatar
STFU n00b!
not a horrible swap, but it's not like changing wheels. plan a week to do it.
Old Jul 3, 2002 | 04:40 PM
I figured it would take a month or so, I may want to swap out the entire interior if I decide to do this.
Old Jul 3, 2002 | 05:34 PM
dmontzsta's Avatar
Ford Only.
Sounds like me It is not too easy, but can be done. Much easier with a donor. I would recommend using the 5 speed ecu and wiring harness, so you dont get a check engine light. If you come to cali I can have the trans swapped in both cars for $500 and the trans and engine in both cars for $1000
Old Jul 3, 2002 | 07:23 PM
D-sta's Avatar
Good luck sounds like a big *** job but anything to save the max.
Old Jul 3, 2002 | 09:15 PM
I'll have the complete donor car (minus mashed in front clip) tight outside the garage for the operation. That should make it easier. I've got 2 cherry pickers, and 2 engine stands. This is all IF the insurance doesn't want too much to get it back.
Old Jul 3, 2002 | 09:47 PM
I assume that I will be able to leave the stock wiring, just change the ECU, the engine and the tranny? Will the same mounts work? OR do I need to swap some of those as well? I also assume that I just punch out the hole in the firewall, then mount and hook-up the clutch pedal? Anything out of the ordinary to watch out for? For some reason the gentleman who sold me the car thinks there are differences between the 2 years. I thought they would be the same since they are both VE engines.
Old Jul 3, 2002 | 10:38 PM
MrGone's Avatar
so any news on your frame?
also what is too much to get it back?
later
MrGone
Old Jul 3, 2002 | 10:42 PM
Tom's Avatar
Tom
A/C
If I remember correctly, 1992 was the last year of the R-12 refrigerant A/C and 1993 on models had R-134a A/C. If this is the case, some parts are probably different.
Old Jul 3, 2002 | 10:45 PM
MrGone's Avatar
hmmm thats kinda wierd because i would think they would do the change between 1991 and 1992. my 93' has R-134a. what about GXEs, do any of them use R-134a or do they all run R-12.
MrGone
Old Jul 3, 2002 | 11:01 PM
Tom's Avatar
Tom
My 92 GXE uses R-12.
Old Jul 3, 2002 | 11:29 PM
Maximamike's Avatar
Other than being illegal in many states emission/inspection wise. It should go off without a hitch.
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
