VE T.B. Bypass causing overheating ?
Old Jul 10, 2002 | 11:42 AM
MAX420's Avatar
What's up guys, well I did the by pass yesterday morning and got through it, Then later on in the day I was waiting outside of my house and saw the needle creep up all the way to "H".....I was wondering if the bypass effected it in anyway?...? I redid it and it didn't over heat, so im guessing it somehow caused it to over heat......any input would be appreciated, Thanks in advance
Old Jul 10, 2002 | 12:01 PM
crazy4maxima's Avatar
dayum i guess that i wasnt the only maxima
out there with over heating problems... WTf is going on ... this is my first summer as an owner and its stinks.. I dunno where to start.. hope that you slove your problem.. I am jsut starting on mine.
Old Jul 10, 2002 | 12:14 PM
PATRICK94SE's Avatar
Did you replace the coolant you may have lost while doing the by-pass?
Old Jul 10, 2002 | 12:19 PM
MAX420's Avatar
yes
Old Jul 10, 2002 | 01:09 PM
Matt93SE's Avatar
STFU n00b!
Originally posted by MAX420
yes
are you SURE you got all the air out of the system?
common thing on the VGs to get an air pocket in the engine where the temp sensor is, and the temp gauge in the car goes sky-high- even though the engine is still running fine and temps are under control.
that's why you need to bleed the air from the system when you open it up.
Old Jul 10, 2002 | 01:21 PM
MAX420's Avatar
Yes I did that, But I will do it again today and see if the samething happens again. Thanks for the replies.
Old Jul 10, 2002 | 03:24 PM
Michael's Avatar
Back in a 3rd Gen.
How did you do it? I did this the other day but did it a little different. I had all the stuff off around there because I was working on something else and when I was hooking the hose back up I noticed that the hose was long enough to just pull around and connect to the outlet of the IAC which bypassed the tb. The way I did it I didnt need a pipe in between the 2 hoses. This may be the way its done by most people because I never researched it but remember reading about someone getting a small tube to connect the hoses together.
Old Jul 10, 2002 | 08:05 PM
MAX420's Avatar
Yes, I connected it using a copper tube. Your idea is very interesting, It should be able to connect straight to the other inlet. Thanks a lot for the info, I will try this tomorrow.
Old Jul 10, 2002 | 08:20 PM
Michael's Avatar
Back in a 3rd Gen.
I just read my post again and it sounded kinda confusing so to clear it up for anyone else that reads this thread I will explain.
there is a hose that goes from the iac valve to the t.b. and then their is a hose that comes out the other side of the t.b. to the motor. I took the hose off of the outlet of the t.b. and moved it over to the outlet of the iac valve(after taking the hose off that leads to the t.b.). That bypassed the t.b. without any need for a tube. I double checked to make sure the hose wasnt crimped when I did this and just checked again and everything is fine.
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
