FS: HID RETRO’D PROJECTORS (E46) with corners (super clean install!)im not
SubscribeHey guys I literally just finished making these after several weeks of custom fabrication and hard work. The projectors are out of a BMW and are bixenon. If desired you can wire the shield to your high beam and it moves the shield in the projector, emitting a vast glare of light. The headlights came off my car and were about a year and a half old. They were custom painted… black high temp on the edges and shroud and chrome spray paint on the bezel and reflector. The shroud was custom made from galvanized roof flashing, and was a b!tch to trim and fit about 30 times each side. The bezel is a 3” pvc pipe fitting. A light amount of gray gasket sealer was placed in the rear where I cut out a hole for the *** of the projector to poke through so no water seeps in as well
I’m picky as he11 when it comes to looks and as you can see everything is as neat and as clean as can be. No silicone all over the rear of the light. No discoloration in the lenses. These come with custom enterprise corners to match that are only a few months old as well. I have a wire harness with relays that was given to me by HOMERMAC when he gave me the projectors last summer. I’m sure u can find wire diagrams if you search yahoo or google. Theres not much else to say.
PM me for any Q’s.
do not low ball me…
I am located in NJ if there are any local buyers.
PRICE- $550
i need to take better pics tomorrow in the daylight. the garage lights just werent cutting it... heres a few
pics of the rear.........
the corners..
PM me for any Q’s.
do not low ball me…
PRICE- $550
the corners..
Quote:
Originally Posted by Dark99GLE
price? 10char
sorry i wasnt done editing the thread. i hit post thread instead of preview by accident
Quote:
Pics of mounting/adjusting screws?
got them from HOMERMAC. he said he got them from and m3 or m5. one of the M's. i do not have pics of them on my car but i did put them on my car today before initially mounting them to double check their direction before placing the shroud and bezel on. Originally Posted by Flava_24/7
Exactly which BMW did these come out of? Any pics of the cutoff? Pics of mounting/adjusting screws?
with the way i mount the projector into the housing.. there is no way thay are crooked/ impossible to aim... they will both be straight as well...
the way i make projectors... (this is my 2nd retro)
take a 2-1/4in hole saw and measure the hole saw so it sits completely even around the socket.. then drill.. so i have a hole that is perfectly where it should be. not too far to the left or right. so when i place the projector into the housing and make sure its sitting even from both turning the headlight straight up and make sure its aimed straight and in line with the hole and on its side makign sure it isnt aimed too high or low.. this is all you need to pretty much make a consistent retro. my previous retro came out perfect and i used this same technique. no there is no pics of the cutoff. sorry flava. they are bolted in, in all four corners with nylon lock nuts. then gasket sealed in the rear.
i hoped this helped tho. if ur confused or unsure about anything i said, pm me and ill help you out. later man
Quote:
alot of ppl have been asking but if someone just wants the headlights then ill sell them seperate.Originally Posted by drgonzo
Any interest in selling the corners seperate???
Quote:
correct. i do have them but im gonan need them for my next setupOriginally Posted by jvelos3
are these just the projectors in the housing? so NO ballasts, igniters, and bulbs right?
