FS: Custom CNC'd IACV plate for relocating or 00VI
Old Nov 29, 2007 | 08:01 PM
goldtooth's Avatar
$65 shipped
Paypal: tomtruchan@gmail.com (No credit or debit)
Old Nov 29, 2007 | 10:29 PM
maxpeed96plat.'s Avatar
How much are they new?
Old Nov 29, 2007 | 10:38 PM
black_maxed95's Avatar
i think his is new...you arent gonna find these sold by a company new, hence the "custom made" part
Old Nov 29, 2007 | 11:00 PM
I know they're custom (by stephen), I just haven't searched how much ppl were paying for a un-used one...Anyways might just run the 5th gen IACV, read that adjusting the idle's a pita. thanks
Old Nov 30, 2007 | 01:38 AM
mastercater7's Avatar
VQ35 FTW
So I have always wondered about this, if I have the 2000 upper, lower, fuel rail and injectors, and tb, is this the only other thing I need? Ready to buy also.
Zack
Old Nov 30, 2007 | 02:13 AM
Zack
it all depends on how you want to rig it up, you could use the 00 iacv and not use this. as far as i know this adapter plate makes it easier to hook up the iacv. however then you will need a block off plate with vacuum lines for below 00 TB where the 00iacv goes.
and also when you say is this everything i need...you could also use a 00 rear valve cover and rear ignition coils or you could customize the 4th gen ones.
also you will need a 00 egr guide tube or a block off plate for that too.
it all depends on how you want to rig it up.
and also you will need some sort of rpm switch ofcourse
...damn i cant wait to finally be able to afford an 00vi, ive done so much research....for some reason i just bought a snow board instead...
Old Nov 30, 2007 | 03:06 AM
Curt's Avatar
Well, I bought mine new from StephenMax a few years ago (don't recall the price), but the one being sold here certainly isn't the same design. Mine has a circular relief about an inch-and-a-quarter in diameter machined on the face that marries up to the IACV, and a single hose nipple in the middle of that coming out the back side. For the life of me I don't understand why you'd want or need 2 hose nipples on the back: there's only one function that the IACV performs, and even then lots of guys have a hard time figuring out where to hook up one hose to the UIM (let alone two).
Don't see any reason why this one wouldn't work, but why the 2 hose nipples is a mystery.
Old Nov 30, 2007 | 04:41 AM
goldtooth's Avatar
I had a hard time getting the 3.5 swap to idle right, so I decided to try something new.....
Old Dec 4, 2007 | 04:01 PM
goldtooth's Avatar
ttt
Old Dec 5, 2007 | 07:38 PM
juani's Avatar
Rockin' VK56!!
if you can do 60 shipped, consider it sold.
Old Dec 5, 2007 | 08:50 PM
goldtooth's Avatar
paypal it and its yours
Old Dec 5, 2007 | 11:01 PM
juani's Avatar
Rockin' VK56!!
payment sent
do you happen to have gasket for iacv?
Old Dec 6, 2007 | 04:53 AM
goldtooth's Avatar
no, but you can go to an auto parts store and get a sheet or a roll of gasket material and trace the outline and cut one urself, thats what i did.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
