FBSS air suspension forsale, comes with 2 tanks two viar 450 chrome compressors and all gauges brass fittings valves ect. Struts in the front and cylinders in the rear, asking 650 plus shipping, will post pics of parts off car this weekend, let me know if your interested. thanks
Brandon
Brandon
could u also shoot a video of them working ?
I'm in Lexington/Louisville.....
Is this a universal kit because I might be getting a Q45 or 2001 maxima. Do you know if it would work? Also, how long did you have tit on your maxima?
kit is for a 95-99 maxima, not sure if it will work for an 01 or not, I have had it on my maxima for 4 years, but I only drive it to shows so I would say that it only has 9,000 miles on the air ride.Originally Posted by 96blackmaxSE
I'm in Lexington/Louisville.....Is this a universal kit because I might be getting a Q45 or 2001 maxima. Do you know if it would work? Also, how long did you have tit on your maxima?
Quote:
just installed new coilovers, sorryOriginally Posted by ray_289
trade for coilovers?
Quote:
Why did you trade out the air ride for coilovers?Originally Posted by euromaxima
Would you recommend air ride on a daily driver?
took pics but sd card messed up and won't load pics, I will get them loaded tommorrow, I swaped out cause Im turbocharged now and want to take it to the track. Air ride is ok for daily driver just make sure you use airbrake anitifreeze in the air lines in winter cause the vavles will freeze up if you don't.
I'm interested, just tying to find out more about air ride suspension. I've never looked into it before...
If I picked them up would you help me with the install?
sure it is pretty easy we can run everything and I can show you haow to install everything else. take about 4 hours to run stuff.
I looking on getting them from you email me the best price you take ship to 60446 IL... I had air bags on my 93 max and I have a 2001 and a 98 max now that I will install it on the 98 max... I see you have strutbags in the front and bags in the back is that right? and do you have the dumps with the kit and are they working fine if not I can order new one which will be better...
So let me know.....
So let me know.....
Quote:
How long did you use it for?
I have 3,000 is everything, all fittings are brass, fittings were 10-25 bucks each, it has been on the car for 4 years, but I only drive it to shows so I would say it has around 10,000 miles on it all.Originally Posted by Kadantsev
How much was the system originally when you bought it?How long did you use it for?
Depends on how low or high you ride, if it is slammed it rides rought if it is raised to high it is bouncy and if you ride bit lower then stock is rides like a caddilac. I like it but I wanted coilovers since I turbocharged the car.
i might be interested on this but.. is this a straight bolt on or am i gonna need to weld,cut or watever? and is there like a written step by step procedure on how to install this? coz the shops around here will prolly rape me for price installation...and how much the shipping to 78628?
it will be about 65 bucks to ship, there is 5 boxes that have to ship its is complete bolt on, and easy to install, pull factory stuff out and put in air bolts right up.
I wish i had the money for this..how much weight can the air bags support? and with the air bags lifted all the way up is that stock hieght or alittle higher?
Quote:
not sure on the weight but it will hold the maxima up just fine, all the way up is 2 or 3 inches higher than stock.Originally Posted by JEXTEL
