ME KEYLESS ENTRY REMOTE FOB
Old Feb 7, 2012 | 11:55 AM
I30TinME's Avatar
SOLD.....Used, button icons worn, but very serviceable. Battery included although not certain if it's any good. Can't test as I have sold the vehicle. This was a third remote I forgot about. $20 shipped. Guaranteed to work or your money back.
and for reference, how to program:
1. Close and lock all doors with the drivers side power lock/unlock
switch.
2. Insert key into ignition and remove it from the ignition key cylinder
at least six times within 10 seconds. Your Hazard Lamps will flash
if you have performed this step successfully(Withdraw key
completely from ignition cylinder each time ). If this procedure is
performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push LOCK button on the keyless remote. Your
Hazard Lamps should flash. (Do not press the button more than
one time in the above step). If the button is pressed more than one
time, the programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock
then lock all doors using the drivers side power lock/unlock switch
and within 5 seconds, push LOCK button on the next remote. Your
Hazard Lamps should flash. Repeat this step for each keyless remote
(including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition,
Open door, Test Remotes
Last edited by I30TinME; Mar 7, 2012 at 01:00 PM. Reason: added guarantee, I just can't test it as I sold the car
Old Mar 6, 2012 | 11:16 AM
I30TinME's Avatar
Old Mar 6, 2012 | 10:39 PM
Boothers96's Avatar
DIBS!! lol pm me info....good as sold.
Old Mar 7, 2012 | 07:10 AM
I30TinME's Avatar
PM sent....
Fbana41
Aug 29, 2016 12:18 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
