Funky power problem
Old Jul 11, 2002 | 09:49 AM
Wylan's Avatar
Funky power problem
My car is a '98 Maxima GLE, fully loaded and here is my problem.
Let the car sit for a week at a friends house, he was going to fix some minor body problems while I was on vacation. Came home to pick up the car and he told me the battery went dead. He charge it and it started fine. The next morning the car would not start, I thought bad battery. I put a battery from my old Chevelle in the car just so my girlfriend could drive it to work. The parking lights went on, misc dash lights lit up, all with the key off. Went to start the car, nothing. Put the old battery back in and all the lights went off, but it was to weak to start the car. Did not try to jump it because it was real late and I was going to buy a new battery the next day. Next day I put in the new battery. Car started right up, but the dash lights, radio, windshield wipers, power windows, power locks, and alarm system did not work. Drove the car for about 5 min. and pulled into the driveway. Turned the car off and then tried to start it, nothing. Looking under the hood, I noticed the fuse/relay block next to the battery controlled all the components I mentioned above. Is there a main fuse for that particular circuit? If so where is it?
Any help would be appreciated.
John
Old Jul 11, 2002 | 12:21 PM
Nismo3112's Avatar
Custom User Title
woah...sounds like you max is cursed or something sorry to hear that dude..
Old Jul 11, 2002 | 12:37 PM
MaxJag's Avatar
Re: Funky power problem
I've got a similar problem. But Mine is when I take out the key from the Ignition the clock and radio stay on. What the **** is The problem?
96 GLE
Old Jul 11, 2002 | 12:58 PM
Nismo3112's Avatar
Custom User Title
is it ONLY your clock and radio? its possible that those two items are powered by the same accesory power wire..im guessing its your ignition selinoid (thing u stick your key in)
Old Jul 11, 2002 | 06:34 PM
nadir_s's Avatar
vicodin ... gift of life
Re: Re: Funky power problem
96 GLE
sounds like a sticky relay...
what do you guys thiNk?
Old Jul 11, 2002 | 07:33 PM
MaxJag's Avatar
Yeah both of them. Does something need replacing?
Holla
Old Jul 11, 2002 | 07:58 PM
97GLE's Avatar
You should check all the fuses in the fuse panel at you knee, then in the box under the hood. If that doesn't solve it then you might have a bad solenoid.
Old Jul 11, 2002 | 09:45 PM
Wylan's Avatar
I found part of the problem tonight, a couple of fuses were blown under the dash and a main 120a fuse in a fuse holder next to the battery was blown. What a pain in the *** to get out. Of course it is a Nissan only part, so I will get one tommorow. I hope this will fix my problem.
Old Jul 12, 2002 | 10:52 AM
MaxJag's Avatar
About how much would a new solenoid run me?
96 GLE
115K
Old Jul 12, 2002 | 08:16 PM
Nismo3112's Avatar
Custom User Title
I checked on wwww.car-part.com and they ranged from $35 to $150..they say they come with a key so im guessing if this part is replaced your old key wont be any good. But before u buy ANY parts, be 110% sure that part is the part thats causing the problem.
Old Jul 14, 2002 | 01:54 PM
MaxJag's Avatar
This is a funky power problem.
Hopefully the culprit is a fuse or relay.
I'll start with the least cheapest parts first.
Holla at the fast MAXJAG
[QUOTE]Originally posted by ImStockBaby
I checked on wwww.car-part.com and they ranged from $35 to $150..they say they come with a key so im guessing if this part is replaced your old key wont be any good. But before u buy ANY parts, be 110% sure that part is the part thats causing the problem. [/QUOTE
lowpost99
Oct 26, 2025 06:53 PM
DJLAX152
May 4, 2021 11:46 AM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
