reverse battery connector, helppp!
Old Jul 12, 2002 | 06:31 PM
mipinc's Avatar
I am so stupid that I can't beleive myself when I connected the battery on my 95 reverse. Now my power window, brake light, power lock, and fan blower does not work at all. I am in big trouble. all the fuses in the front and inside compartmaent are ok. Please help!!! The car does start and run
Old Jul 12, 2002 | 06:44 PM
karguy's Avatar
Re: reverse battery connector, helppp!
I would carefully recheck every fuse with a meter to ensure they are not bad even if they look good. you need to get your hands on a electrical wiring diagram to see what all of those items have in common, it could ignition switch, relay, wire or connector. In the meantime I'll look at my FSM to see if I can find any commonality. I'm betting on a fuse or relay (gut feel)!
Be well!!!!
Old Jul 12, 2002 | 08:12 PM
Ravq's Avatar
This happened to my little brother. Have you tried leaving the battery disconnected for awhile and then reconnecting it? It worked for my brother and he had no blown fuses either. I think the ECU has some sort of circuit protection when it comes to power surges.
Old Jul 12, 2002 | 08:23 PM
mipinc's Avatar
found blown battery fuse
I found my battery fuse FL140A blown. But I can not remove it. How can I remove it? Where Can I buy it?
Old Jul 12, 2002 | 08:26 PM
Ravq's Avatar
Re: found blown battery fuse
Try some pliers. You can get a fuse at an auto parts store.
Old Jul 12, 2002 | 09:07 PM
Pervis Anathema's Avatar
I did the exact same thing on my VG auto. To fix it I had to:
- beat my head against a brick wall
- replace the alternator
- replace the battery
- replace a fusible link
Good luck, I feel your pain!
Old Jul 12, 2002 | 10:01 PM
karguy's Avatar
I just looked at my car, you should be able to pull the fuse out.
However I believe you'll have to get it from a Nissan dealer or an Infiniti dealer. I have never seen any fuses like that at parts stores. The service departments here are open on Saturdays till noon.
If its only a fuse you got lucky!
Be well!!!!
Old Jul 13, 2002 | 05:49 AM
Re: Re: found blown battery fuse
Be well!!!!
Yep, go to the dealer. They had to special order mine.
Old Jul 13, 2002 | 09:18 AM
DaddyMac's Avatar
damn, that sucks. do like Pervis Anathema suggested and find some bricks j/k
you are in luck though, I have all my relays and fuses. find out what you need and I'll hook you up.
Old Jul 13, 2002 | 09:25 AM
karguy's Avatar
Its situations like this when you realize the value of the forum. Here is a guy who might have what you need. Good luck!
Be well!!!!
Old Jul 15, 2002 | 07:30 AM
mipinc's Avatar
The problem is fixed
Thanks everyone for your help. The problem is fixed but I am not sure If I did the right thing. I was pulling the fuse out whe the top part came apart. It connect the two metal strips by pullign them together. Now the one shid has the thin connector to be blown in the case of over current flow. The car is running fine after that. Just like before.
Old Jul 15, 2002 | 07:50 AM
karguy's Avatar
Re: The problem is fixed
Man you are sooo lucky! You need to go to Vegas with that kind of luck!
Be well!!!!
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
