Installed Y-Pipe, causing a problem.... squeeking
Old Jul 15, 2002 | 07:23 AM
multiplexor's Avatar
1. The ypipe is a great mod, changed the sound of my car. Makes it sound bigger, especially when it's warmed up!
2. Once it's warmed up, it's creating a squeeking sound
Basically once i've driven it for about 5 minutes, any bump i make will cause the whole exhause system to make a squeeking sound.
If i park the car, turn it off, get out and lightly hit the muffler with my foot, i get a squeeking sound. It sounds tunnel like... as if it's coming from the muffler, but also futher in the pipe.
Anyone have an idea or solution to this problem?
Old Jul 15, 2002 | 07:28 AM
MaximaPower's Avatar
squeak??
hmmm..best thing is to get under the car and shake the pipe and see where the squeak is coming from.
Old Jul 15, 2002 | 07:32 AM
kratz74's Avatar
I had this issue. For me it was the bracket where the rubber hangers to the cat were removed and the cat was hitting those brackets. I just bent them outta the way and whoila...gone. This is the issue for most pipe rattles.
Old Jul 15, 2002 | 07:36 AM
yea...those hangers were a problem for my bro's car,but it wasn't a squeaking noise
OT: wat is that in ur sig? hayabusa??
Old Jul 15, 2002 | 07:40 AM
it's possibe i guess... the budget ypipe doesn't com with an extra hanger piece... i guess when it gets hot the squeeking starts because of the rubbing. ( Not to be taken the wrong way... )
And once the car is off for 30 seconds, the squeek goes away.
Though once i take off and drive again, the squeeking will start after like a minute, since the pipes are already hot.
Old Jul 15, 2002 | 07:45 AM
breaux124's Avatar
The Y-pipe should have already had the hanging piece. You just need to bend it back so it doesn't hit the frame.
Look here:
http://www.greghome.com/images/Maxim...int_at_Cat.jpg
Old Jul 15, 2002 | 08:02 AM
Look here:
in that pic... i don't have the right hanger, but i do have the left one, with the big metal piece and all... The left piece might be touching the pipe and when hot creating that loud sound? I'll have to check to see if it's touching.
Old Jul 15, 2002 | 08:11 AM
that's weird...i thought the hanger was just one piece
Old Jul 15, 2002 | 08:26 AM
I dunno, I only had the left hanger metal piece, attached to the y pipe. the oem pipe had one on both sides, which attached to the rubbers.
Old Jul 15, 2002 | 08:32 AM
let me get this straight.
ur budget pipe came with a hanger on the left side?
i jus used the hanger from the oem pipe...well i worked with a wsp pipe and it didn't come with it's own hanger
Old Jul 15, 2002 | 08:40 AM
yup... the oem pipe has metal pieces on the pipe the come out, to goto the rubber piece. the y pipe only had one extruding metal piece.
The one on the left side. Now i have a rubber piece attached to my car just hanging on the right side with no metal piece from the y-pipe to attach to.
Old Jul 15, 2002 | 10:49 AM
jerzeeMax's Avatar
Looks like wrong pipe or pipe that also fits a different car. The support from the header bolts and the hangers on the cat are the only things that are supposed to be there to hold the pipe up, other than what also holds up the B pipe and the muffler. But hey, if it fits just find a way to bend it out of the way.
Old Jul 15, 2002 | 11:08 AM
breaux124's Avatar
Actually the Stock Y-pipe and Stillen Y-pipe have a support bracket right before the flex section, this is used to help support the Y-pipe. I've never seen this on a Cattman, Warpspeed, or Budget Y-pipe.
Look here:
http://greghome.com/Greg's%20Garage/...S%20Y-Pipe.htm
And here:
http://integra.vtec.net/geeser/megamax/ypipe.html
Old Jul 15, 2002 | 12:07 PM
as a side note, I have this crimp in my pipe and i feel like i'm losing a bit of power cause of it... ;-)
http://greghome.com/images/Maxima%20...natorCrimp.jpg
oh, and i have a ford muffler.. just noticed recently.
Old Jul 15, 2002 | 04:16 PM
vipervadim's Avatar
I like Maximas
oh you're definitely losing power there. need that piece straightened out!
Old Jul 15, 2002 | 07:39 PM
kratz74's Avatar
OT answer: Yes Suzuki Hayabusa.
MAx mods are done, now I play with the 'Busa. Just learned how to bring it up in 3rd at around 110 mph
sctludwig
Sep 1, 2022 01:32 PM
MaxLife17
Jun 27, 2019 01:37 PM
dcam0326
Sep 7, 2015 07:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
