I have Redline MTL, Do I Need to Chg. Tranny Filter?
Old Jul 15, 2002 | 11:30 AM
thisasian's Avatar
I've already done a search, and read old posts. None mention replacing the filter, or droping a pan or anything like that. Just a fluid change. My car has 109k on the odo, and I don't know too much about the car yet, should I consider or do I even need to replace anything else aside from the fluid itself?
Thanks,
-Walter
Old Jul 15, 2002 | 11:36 AM
mtrai760's Avatar
'Trynna' is not a word
The tranny doesn't have a filter, just a screen. If you have particles big enough to get trapped in that screen, your tranny is probably done for already...
Old Jul 15, 2002 | 11:42 AM
rmb's Avatar
rmb
Redline MTL or Redline MT-90 are gear oils for manual transmissions only. Therefore there are no filters or pans. Warm it up fully , turn it off, let it sit for 10 minutes. Open the fill plug first(to make sure you can). Open the drain plug second. Drain it completely. Torque the drain plug to spec. Fill it up. Check it. Close the fill plug. Drive it around again. Park it again. Open the fill plug and check the level again. Close it up...
Thats it.
-RMB
Old Jul 15, 2002 | 12:01 PM
thisasian's Avatar
Thats it.
-RMB
Gravy! Thanks
Old Jul 16, 2002 | 09:17 AM
MaxKlinger's Avatar
Is there a seperate fill location for the auto trans fluid or should it be filled via the trans dipstick tube? I haven't done this before, and that's where I was told to fill it. . .
Old Jul 16, 2002 | 09:21 AM
iwannabmw's Avatar
It goes in the dipstick tube
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
fx4five
Oct 1, 2015 04:58 AM
