Automatic Gear Shift Knob Change
Old Dec 9, 2000 | 09:55 PM
Car With No Name's Avatar
does anyone have input on installing a Levoc Gear Shift **** for an Automatic 96 maxima?
I ran into a problem with the 2 wires that come out of the console, they are not long enough for splicing. Can the housing come off of the console without taking the whole thing apart?
Please help if you can.
Old Dec 10, 2000 | 12:28 AM
mrloyd
if you havn't cut the wires yet, the best way is to get a solder gun and burn them loose from the points of contact on the ****. These are visible from the right side if you put your head down beside it. If you've already cut them too short you will need to take the stuff apart to trace them down to where you can splice. Its not that hard.
Old Dec 10, 2000 | 01:18 AM
Thanks for the info...I do appreciate it.
I'll be taking off the console...
How do you like your ****?
Old Dec 10, 2000 | 02:41 PM
mistiso23's Avatar
Just bought one....
Hey guys... I just bought that Levoc shift know for a auto. So it's not hard to put in? I was thinking of waiting till srping to put it in... since it's kinda cold already here in Chicago... but any pointers or tips I would greatly appreciate... thanks guys.
Neil
Old Dec 10, 2000 | 05:45 PM
Nathan's Avatar
Hey guys, if you want to know how to install the Levoc **** go to Chestons site: http://www.maximadriver.com under the How2 section.
Old Dec 10, 2000 | 08:21 PM
mistiso23's Avatar
Hey thanks
Thanks nathan... I'll check that out.
Old Dec 10, 2000 | 08:30 PM
AndyXXL's Avatar
I installed my 2 days ago. Removed the whole console box, without cutting any wires.
Andy
Old Dec 10, 2000 | 11:31 PM
Hey Andy....did you put on the levoc ****?
What's up with all of the extra's in the package?
did y0u use all of that stuff?
How do you like it?
Thanks guys for the input!!!!!!!!!!!!!!!!!
Old Dec 11, 2000 | 12:33 AM
AGnismo's Avatar
You can check out my website (click to the left). I put a section on there because tons of people were emailing me about how I did it. Hope that helps.
Old Dec 11, 2000 | 07:09 AM
AndyXXL's Avatar
How do you like it?
The two major things that I've used were the black plastic tube that u have to cut and one screw. There was something else, but most of the stuff is still in the box.
You need only one screw for the new **** unlike the stock one that used two. And put the screw in the upper hole, that way your **** won't be very tall.
Andy
Old Dec 11, 2000 | 07:13 AM
AndyXXL's Avatar
Hey AGnismo
What springs did u use to drop yer car so low? Just curious.
Old Dec 11, 2000 | 12:10 PM
Thanks for all the info and tips guys....
I show all my appreciation by ripping a big ol scratch for ya all.....wooohooo
Old Dec 11, 2000 | 07:24 PM
Hey Andy....
How nuch did you cut the black tube? Did you do it the 15mm they recommend?
AGnismo...you have a nice site, and I like what you did with your shifter.
Old Dec 11, 2000 | 09:09 PM
AndyXXL's Avatar
Re: Hey Andy....
Yeah, I think I was using their formula. Cut what they say, if it's still long cut a little more, try not to cut too much the first time. Push the **** all the way down, the button on top shouldn't be loose. Also before you completely install the shifter try the OD button, I made a mistake connecting OD wires wrong, good thing I checked before putting everything back together. Also check how you **** **** is switching between gears, it should go smooth.
Hope this helps a little.
Andy
Old Dec 11, 2000 | 09:16 PM
AndyXXL's Avatar
Re: Re: Hey Andy....
Originally posted by AndyXXL
[IAlso check how you **** **** is switching between gears, it should go smooth.
Andy [/I]
Whatta hell, why did it block the word "shift"???
Did i type a bad word instead? hehe
[Edited by AndyXXL on 12-11-2000 at 11:22 PM]
sctludwig
Sep 1, 2022 01:32 PM
pjgreek
Sep 9, 2015 09:30 PM
videomano
Sep 8, 2015 03:28 PM
dcardello
Sep 3, 2015 11:44 PM
