how to replace climate control lights??
sup guys. i need to get some good detailed directions on how to replace the bulbs behind my auto climate control. i already got the bulbs from nissan but need some good instrucions.
i saw somewhere taking the vents out but is that necessary??
Re: how to replace climate control lights??
Stero Removal Instructions
so does anyone have any good tips on how to get the climate control thing out of the car???
Check this place out, the instructions are simple.
Post if you any other question.
hey thanks man. that helped me out alot
so it looks like i just pull the vents and clock forward and down at a diagnol?? kinda like south west on a compass, or do i pull forward then down??
Just to let you know, the process of replacing these bulbs is a delicate task if you have the patience. I replaced all three bulbs in mine last month. The unit is a "puzzle". What I mean is that the unit must come apart, piece by piece. The circuit board is held by two screws in the rear. Once removed, the fan contor **** must be removed. Then if your lucky, all the climate control buttons (the "little men" buttons) will fall out. All these pieces must be removed in order to get to the circuit board. Here, there is three bulbs. Be careful, the bulbs are so tiny and delicate, that I broke one trying to remove it. Luckily, I bought extras just in case something like that would happen. Well good luck!
My climate control lights go on and off
I just recently noticed that my climate control lights go on and off on my 95 maxima GXE. At first they started blinking. Now they come on when I first start the car at night. After a while they go off. When I hit or tap the climate control area, the lights come back on temporarily. Should I just change the bulbs? If so, can I get the bulbs from any autostore like PepBoys? Or should I just replce the bulbs with blue leds? Does anyone have a write up on that? Thanks in advance.
MikesChevelle
Mar 2, 2021 11:32 AM
