could i beat a new se-r?
Re: could i beat a new se-r?
Originally posted by bizzy
one of my freinds just got a new se-r 5-speed. i have a 95 maxima Se 5-speed. who would win? would i stand a chance? we are both stock.
Re: Re: Re: could i beat a new se-r?
Originally posted by MaximaPower
a 95 5sp driven right vs. a specV driven right..the max should win
i thought spec-V were 6spds?
Originally posted by Y2KSESteve
Spec-V driven right would beat you
Unless you are a really poor driver, or your car has a problem, you will beat him easily.
Stock I have seen the Spec-v run 15.4 in the 1/4(according to road & track) my best 1/4 run (stock '97 5spd) was 15.3 in hot and humid weather, I have read our cars stock run as good as 14.8 (I'm sure in good cool weather) in the 1/4. A 5spd should have no prob with a 6spd v-spec, there is no match with the low end torque...as far as an auto max, that might be close.
Don't forget the mileage you have on your car . If both cars were new, the maxima would have a bigger chance of beating the spec V. I've heard of ppl running 15 flat with their stock 5spd max if weather conditions and driver are good. You have a 95 which is the lightest year, so I think you have the advantage. If you do beat him, it will be by very little, but give it a go and let us know
Stock 4th gen Maxs have run well into the 14s. I ran a 15.2 in my 95 GXE Auto with just a homemade intake.
Dont underestimate the 4th gen in the hands of a good driver.
Stock for stock I think the max would walk, but it depends on how far you race. Most people shut down before a full quarter-mile on the streets. I'm sure the spec-V with it's nimble size and v-lsd probably launches out in front of the max, but the max eats up the gap later on. But if we're talking mid 15s versus low-to-mid 15s, that gap might not get fully recovered by the max if you only race to say, 60-75mph.
*shrug*...I always say, why post about it in wonderment? Go out there and put it into action, and do it in a way that you can have fun w/o endangering others. And don't let the Spec-v take you into the twisties
Also, don't let you friend race/beat up his ride until *after* the break-in period
my friend with a 5 speed 99 max 82000 miles with intakes, a apexi muffler and a stillen y-pipe , raced a brand new 6 speed spec V with aem intakes and exhaust and he pulled on him by 4 car lengths.....belive me if u drive right u will take that **** its slow. remember its 175 hp at the fly wheel its only like 145 at the wheels,
I ran 14.8 stock in 85 degree weather with high humidity, at 110K miles. VeeTec ran 14.7 in the Alabama heat. I've raced 2 spec Vs and was severely disappointed with how easily I burned them, giving them a severe jump both times. 175hp and 175tq, 6spd LSD and stock 17's are some good stats, but they seem to lack a little bit where the tire hits the road.
A FI Spec-V with other appropriate mods/bolt-ons with some smaller drag-friendly tires would be interesting to see, timeslip-wise. You could probably do everything necessary above and still not spend much in the end. $19k new is a good price for a little project fwd 4-banger.
Straight from the July 2002 R&T.
SE-R Spec V 6-spd
0-60............ 7.3 sec
1/4 mile........ 15.6 @ 90.3mph
Test weight..... 2940 lbs
HP.............. 175 bhp @ 6k rpm
TQ.............. 180 lb-ft @ 4k rpm
Stock-for-stock and driven well you could take it...
SE-R Spec V 6-spd
SE-R Spec V 6-spd
SE-R Spec V 6-spd
B15 SE-R Spec V's usually run 15.0~15.6 stock. A few may tap the 14.8~14.9 range, but those are just like the gen4's who hit 14.8's stock... that is, FREAKS!
I wouldn't worry about outrunning a stock Spec V in a straight line with a stock gen4 5-speed. The turns are another story, though... and bolt-ons are another story, too; the Spec V and the Maxima both benefit greatly from minor bolt ons...
In a longer race you should win. In a short race it will depend on the driver and particular car. Even with the HLSD the spec v is very hard to launch, often with inexperienced drivers spinning through all of first and most (if not all) of second gear. I know - I run a 2.4 sec 60ft due to wheel spin and poor launch technique, but finish the 1/4 in 15.5 @ 91.44 mph in my spec (stock). With that trapspeed and a better launch the ET should be at least low 15s.
Some spec people run 15 flat with a couple claiming 14.9, while others run 15.8+. I don't think it is all driver difference. IMO specs are very inconsistent between cars. I test drove some that felt real slow while others felt much faster. One *missed* while idling (at the dealer).
However, your top end is much better than the spec. In a long race or a race on the highway you should crush it. In a short race if the spec driver can not launch well you will beat it. My first time at the track I ran a 16.9 because I spun through 1st, 2nd, and came off the line in 3rd.
If you had a stock automatic though you would *probably* lose. At least in a 1/4 mile race. I have timeslips racing a 4thgen automatic with ECU and y-pipe. I beat him 2 out of 3 times, and even in the 1 loss I had a faster ET.
Let us know how it turns out :-)
Spec v stock
Maxima with popcharger, JWT ECU, y-pipe, 2.5" pipe, RT cat, greddy, rims, blah blah blah....
Spec v stock
04-16-2020 05:15 AM
doctorpullit
04-23-2017 05:35 AM
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
