Loosening belt tensioner
Old Jul 18, 2002 | 01:57 PM
96SE5Spd's Avatar
I'm replacing the alternator and i need to loosed the belt do I loosen the nut in the center of the pulley and then use the adjuster to loosen the belts?
Old Jul 18, 2002 | 02:01 PM
iwannabmw's Avatar
Re: Loosening belt tensioner
Yes, loosen the nut slightly on the idler pulley and then use the adjustment to take the tension off the belt. You may want to spray the adjustment bolt liberally with WD-40 or equivalent if there is any corrosion present. It's a PITA if it snaps.
Old Jul 18, 2002 | 02:03 PM
96SE5Spd's Avatar
Re: Re: Loosening belt tensioner
Thanks for the help.
05' MaximaMan
Oct 8, 2017 06:36 PM
02PearlSE
Feb 1, 2016 12:37 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
