button lights are out
Old Jul 18, 2002 | 07:27 PM
mohfo's Avatar
I have a GLE and my button lights are not coming on. I can see the display but no button lights. Any ideas?
Old Jul 18, 2002 | 08:45 PM
FameMax's Avatar
Re: button lights are out
its ur bulbs dude, there done, it happens. Nissan sells new ones
Old Jul 18, 2002 | 09:00 PM
pocketrocket's Avatar
Re: Re: button lights are out
I have no idea what lights you're talking about. Radio?
Old Jul 18, 2002 | 09:32 PM
99MaxOnDubsSE's Avatar
If you're talking about the climate control lights, I just put new lights in my friends max today. It's not that hard but takes about an hour. just pull off the plastic around the shifter, unplug the cigg lighter, unscrew the screw that holds the left side of te ash tray in, open the ashtray, pull on the ash tray untill it pops out,. then take out the 2 screws holding the radio, change tray, and the climate control in which are at the bottom left and right corner of the change tray. they are gold colored. after that, push up from where you just took the screws out. this takes a little more force then you'll think but it works without breaking anything. after that the clock and air vents will pop out. grab that from the under side of the clock and pull out and down, that will expose 2 screws. after taking those 2 out the whole thing will slide out. replace the bulbs and your done. hope this is what you need and it helps.
Ben
Old Jul 28, 2002 | 06:18 PM
mohfo's Avatar
I called the maxima dealer to see if they sold the light bulbs, they said it's not the bulb, I have to get a new climate control system. The GLE climate control is different from the other max's. My display shows but no button lights.
Old Jul 28, 2002 | 06:42 PM
Kevlo911's Avatar
Kevlo for President
Re: climate control lights
do not listen to the dealer, if ur display works then its goos , people hav put led's in place of the old bulbs so check that out
Old Jul 29, 2002 | 09:40 PM
thats crazy!!!! at liest spend 2.50 on one replacement bulb from nissan and 20 min of your time to check it out for yourself before you buy a whole new unit!
Ben
flu2000
Sep 8, 2015 02:23 PM
mikebla
Sep 3, 2015 05:37 PM
coasterswim
Sep 2, 2015 07:43 AM
