strange starting problem
Old Jul 18, 2002 | 08:04 PM
x10r10's Avatar
Have the following problem with my 95.
Car starts fine when the engine is cold, but if I have to turn the engine off and then wait a few minutes until I start it again(less than 30 minutes) car cranks fine, will rev to 1200 rpm and then will die. It usually dies about 3 or 4 times before it gets going. Any suggestions as to what could be causing this??
Thanks in advance.
Old Jul 18, 2002 | 08:45 PM
GluteusMax's Avatar
does it crank long before catching when warm?
mine [95 SE 5peed] does this occasionally. it could be vaporisation of the fuel in the lines in the warm engine compartment. i now 'crack' the throttle [just enough to hold about 1500 rev steady if you can picture it]when warm and hold while cranking. works great every time.
good luck-
Old Jul 19, 2002 | 05:48 AM
njmaxseltd's Avatar
Clean your throttle body and your IAC valve. Most likely the valve is sticking a bit.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
trungg86
Sep 4, 2015 04:58 AM
