Help! Trying to take off Idler Pulley!
Old Jul 22, 2002 | 04:54 PM
BlackCat's Avatar
RIP '98 Maxima SE
I've got the car up on jacks right now...d*mn, the space between the body and the idler pulley is like less than an inch!
I tried using a pair of vise grips to turn the nut but it won't work...any suggestions? I'm about to just give up and let a shop do it.
Old Jul 22, 2002 | 05:54 PM
Chunger's Avatar
My other car is a Hybrid
If it's a V2 kit... I didn't do that pulley yet, either...
I'll put it in when I do the SC pulley at the same time... I don't think there's enough room without removing the SC bracket assembly.
Old Jul 22, 2002 | 05:57 PM
Shadow's Avatar
When Jaime (Jay25) replaced my belt for me, he got the idler out while the plate was still in the car. He used one of those gear wrenches, plus he has small hands. And mine is a V2 kit.
Old Jul 22, 2002 | 08:25 PM
JAY25's Avatar
Re: Help! Trying to take off Idler Pulley!
grab a 19MM open end wrench and stick it up there from under the car thats the easiest way to get to it!!!!!!!!!
Old Jul 22, 2002 | 08:40 PM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: Help! Trying to take off Idler Pulley!
19mm? I read somewhere that its 14mm... I just tried a 15mm open end wrench and there's a slight gap left...unfortunately the nice and shiny open end wrench set I bought last year did not come with 14mm...Grrrr!
Thanks, I'll try it again next weekend guys!
Old Jul 22, 2002 | 08:47 PM
JAY25's Avatar
Re: Re: Re: Help! Trying to take off Idler Pulley!
You need to go under the car and make sure I doubt is a 14MM bolt but then again it might. I know my is 19MM and shadows was 19MM. And you got a V2 just like us. Just remove the wheel 3Min job remove the 3nuts 2min job and then loose the belt tensioner pulley thats a 14mm nut and then grab a long 3/8 extension and loosen the belt and do it from under the car unless your hands and wrist is made out of RUBBER THERES JUST NO WAY!!!!!!!IN all it should not go over 35Mins tops.
Old Jul 23, 2002 | 08:40 AM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: Re: Re: Help! Trying to take off Idler Pulley!
Thanks Jay25, this sounds alot more promising!
I've loosened the belt tensioner
http://integra.vtec.net/geeser/megam...bolt_right.jpg
with the 14mm socket and extension but I've checked the belt deflection and it seemed to not have changed. I've turned it both ways all the way to the end but there seems to be no difference in deflection. This morning I just turned it to somewhere in the middle and drove it with no problems.
Its strange that you have 19mm for this bolt:
http://integra.vtec.net/geeser/megam...assy_close.jpg
The mechanic probably just reused the original bolt?
Looking at the pulley in its current condition it looks intact. No signs of stress or "melting"...its like how it originally came in the V2 kit. Nevertheless it needs to be replaced in order to remove any
doubts.
When you said to remove the 3 nuts you're talking about the ones by the power steering pump?
Old Jul 23, 2002 | 11:48 AM
JAY25's Avatar
Re: Re: Re: Re: Re: Help! Trying to take off Idler Pulley!
NO NO the ones that hold that plastic guard to access the 14MM nut to the belt tensioner pulley, You have to loosen that nut prior to loosening the belt and then after you tighten the belt then you tighten the belt tensioner pulley nut. Hope that helps!!!
that belt tensioner pulley is a 14MM nut the idler pulley the one you cant get the smooth pulley is a 19MM nut, you dont have it on the pic.
Old Jul 30, 2002 | 08:33 AM
BlackCat's Avatar
RIP '98 Maxima SE
I give up! I nearly f'ed up the nut holding the belt tensioner pulley with the 14mm open end wrench...and now I hear a slight rattle (belt tensioner?) when I step on the brake before shifting out of park.
Old Jul 30, 2002 | 09:09 AM
JAY25's Avatar
dont be so nervous that 14mm nut has to come off to remove that belt tensioner pulley, and then once you remove it then grab your 19MM open end wrench and remove the idler pulley!!
Old Jul 30, 2002 | 09:47 AM
BlackCat's Avatar
RIP '98 Maxima SE
I started to round the corners on the nut with that wrench. Will I be able to pick up a replacement nut from Home Depot or do I have to go to the parts dept at the dealership?
Old Jul 30, 2002 | 01:56 PM
JAY25's Avatar
That 14MM will have to come off with a open end wrench use the close side and use another wrench for leverage if you need to!!!
James92SE
142
Jan 2, 2024 09:23 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
