GOVERNOR AT 115 MPH HELP PLEASE
Old Dec 10, 2000 | 09:04 PM
JERICHO730
MY 96 MAXIMA HAS A GOVERNOR THAT MAKES IT SHUT OFF AT 115-120 AND IT GETS REALLY ANNOYING. IV ONLY HAD MY MAX FOR ABOUT 2 MONTHS AND LOVE IT.. I'LL NEVER OWN ANOTHER CAR.. DOSE ANY ONE KNOW HOW TO GET RID OF THE GOVERNOR???
Old Dec 10, 2000 | 09:10 PM
wicked1044's Avatar
the fields fuel controller will help your problem.. buy why go above 120????
Old Dec 10, 2000 | 09:14 PM
JERICHO730
fields fuel controller??? WHATS THAT HOIW DO I GET IT AND WHAT DOSE IT DO TO MY CAR?? IM NEW AT THIS AND WANNA MOD MY CAR AND THE FIRST THING I WANT TO GET RID OF IS THE GAVERNOR.
Old Dec 10, 2000 | 09:49 PM
CoolMax's Avatar
is invisible
I understand that you are new...
but using all CAPS will not remove the speed governor.
Get a JWT ECU. I'm pretty sure that'll remove the governor.
Old Dec 10, 2000 | 09:54 PM
philpoe's Avatar
4 Maximas and counting
Is there another alternative?
I can't imagine why someone would do it, but couldn't you swap with a SE ECU and get it removed? I guess if you salvaged one and gave back yours + $$ it may go over.
Old Dec 10, 2000 | 10:56 PM
mzmtg's Avatar
Minister of Silly Walks
The fields fuel controller wont help that at all. The governor is programmed into the ECU. A replacement ECU is the only solution.
Old Dec 10, 2000 | 11:06 PM
Stillnmax's Avatar
hmm
or you could get a SE ecu - no govner
Old Dec 10, 2000 | 11:18 PM
SleeperSE's Avatar
Congratulations - you were shafted
- Here's the deal. All automatic equipped Maxima GLE and GXE's (?) had this speed governor programmed into their Engine Control Module (ECU). The 5-speeds and the SE's did not. So, the only way to get rid of this governor is to swap your ECU. That means either an SE chip, or a performance chip (the one you want if you want to go fast). Jim Wolf Technologies (JWT) sells a performance ECU that you would be interested in.
- BUT, chances are, if you bought an automatic, you will not be racing. You will not have the opportunity to reach that speed in a (somewhat) safe track environment. ie, you shouldn't be going that fast on public roads. So, forget the chip and do something else with your money. Read the "Maxfaqs" link at the homepage. You will get your answers. Also, their are links to aftermarket web-sites just below that in the "Links" section. Explore the homepage to avoid embarassment. ;-)
Old Dec 11, 2000 | 03:45 AM
Victim64's Avatar
UPRD ECU not JWT ECU
Has everyone forgot??? This is just as good as the JWT ECU if not better, and it is cheaper!!!!!! Group Buy contact Cheston, and check it out at http://www.maximadriver.com
Old Dec 11, 2000 | 05:54 AM
Whitemax's Avatar
Disco Biscuit
Actually ALL GXE's including 5 speeds have it
I have one. I don't like having it, but since the cost to get rid of it will cost around $500 or so, I will live with it. My wife tells me I don't need to go over 115 anyway.
Old Dec 11, 2000 | 07:14 AM
4D Sport's Avatar
Re: Actually ALL GXE's including 5 speeds have it
I'm going to have to change mine out before my scheduled SCCA Street School in February. Would be embarassing to be limited to 112 on the 3.2 mile Thunderhill FIA road course. So, instead of it being a $175.00 day at the track plus tire and brake wear it's going to cost an additional $500.00... not too bad compared to the higher priced competition schools (Skip Barber, Bondurant, etc.)
http://www.thunderhill.com/
Also, I've heard that the upgraded ECUs with higher rev limiter and more flexible power band will assist in autocross performance as well... I'll have to test the theroy next season.
Old Dec 11, 2000 | 12:40 PM
wicked1044's Avatar
mzmtg??//
the fields afc has been thrown around here and it is said to take away the limiter.. a couple people have bought it and it worked. there a switch on the back to take the govn. off
Old Dec 11, 2000 | 03:37 PM
Synki's Avatar
Re: hmm
I asked Don in Texas about doing this. He said it wouldnt change the limiter. You can do a search about it. Since you ahve a 96, go with the group deal goin on the URDP ECU that is going for 475. It will remove it adn giv eyou big gains. My 99 Cali spec max is limited at 117 now. Doh!
Old Dec 11, 2000 | 03:44 PM
Eric L.'s Avatar
Re: Congratulations - you were shafted
Actually, the only Maxima with the governor is the GXE 5-spd or a GXE without S&C package. All other Maximas don't have the governor, including most GXE automatics.
Old Dec 11, 2000 | 04:25 PM
JERICHO730
my maxima is a 5 speed and it still has the governer on it i do wanna race it but i have to make the $$ to modify my car which im currently in the process of doing i heard some of the ECU units lower gas milage and since u have to put premimum in the max any way gas get a little expensive if i get the SE ecu would my gas milage still be effected like an after market ECU??? sorry i typed in caps before i was working, and im a mechanical drafts person and we have to be in caps all of the time. which is the best after market ECU i saw two diffrent kinds??? any more suggestions or any one else have this problem????
Old Dec 11, 2000 | 04:42 PM
Victim64's Avatar
Re: Re: Congratulations - you were shafted
The UPRD ECU is cheaper and will show the same gains as the JWT ECU, if not even better. So go with the group deal.
[/QUOTE]
which is the best after market ECU i saw two diffrent kinds??? any more suggestions or any one else have this problem???? [/I][/QUOTE]
Old Dec 11, 2000 | 05:02 PM
BrokenMotor's Avatar
5 dollar way or 500 dollar way
5 dollar way - find the speedo wire located behind the centercouncil, cut it, and put a switch on it. so whenever you need to go over 115mph, you can just turn the switch on.
500 dollar way - buy an upgraded ECU.
Old Dec 11, 2000 | 08:51 PM
JERICHO730
Re: 5 dollar way or 500 dollar way
how do you do the switch thing and will it really work??
Old Dec 12, 2000 | 06:36 AM
kratz74's Avatar
Hey Whitemax-you're wife must be related to mine..... B/c I hear that cr@p all the time.
Old Dec 12, 2000 | 07:26 AM
ChiTown Max's Avatar
Make sure you have the right speed-rated tires first. You don't wanna be going 130 and blow out a tire. The limiter was put in place because that's all the tires could handle.
derekinthez
Nov 13, 2022 04:00 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
