rewire fog lights
Old Jul 24, 2002 | 08:11 AM
kenju4u's Avatar
rewire fog lights
anyone have any info on how to rewire the foglights on a 1997 max to stay on even if the headlights are off or on high beam , I did this for a 1990 Toyota Supra I had and it was awsome cause the headlights didnt need to come up during dusk.
Old Jul 24, 2002 | 08:36 AM
Big_Ham's Avatar
MaximaFreak
Re: rewire fog lights
Do us all a favor and search. I usually am not the first to tell people to do that, but this has been discussed SO MANY TIMES and you should be able to find MANY posts/websites to do it.
Old Jul 24, 2002 | 09:08 AM
Albertt's Avatar
Kenju4u: This time it's free...cuz you're new here >>
But next time, do a search...
http://www.users.voicenet.com/~breau...fogrewire.html
or
http://web2.airmail.net/scutchen/max...ht.htm#lowfog4
Have fun.
Old Jul 24, 2002 | 11:26 AM
iregula's Avatar
im glad you at least told em
Old Jul 24, 2002 | 11:39 AM
kenju4u's Avatar
ok so here is a question! I saw in some forms where people were saying they might be having a electrical problem because of this rewire...is this something to be concerned about or is it unrelated?
Old Jul 24, 2002 | 11:48 AM
vipervadim's Avatar
I like Maximas
Are you talking about the problem with the sidemarkers and rewired bumper lights and the 7.5 amp fuse blowing out?
-Vadim
Old Jul 24, 2002 | 12:01 PM
breaux124's Avatar
Re: Kenju4u: This time it's free...cuz you're new here >>
or
Have fun.
Check my sig, I've posted my instructions on my new site too.
And the electrical problem relates to people who have added sidemarker lights and wire them to the corner lights.
Old Jul 24, 2002 | 12:09 PM
kenju4u's Avatar
cool so the fog light rewire should be safe to do.
The rewireing of the relay does that cause the fog lights to share the power/amparge with the side marker lights? and if it does wouldnt the foglights be not as bright as they would be in the original configuration?
Old Jul 24, 2002 | 12:44 PM
guido_sst's Avatar
They're not sharing the same power source.
All you're doing is changing the signal wire for the fog relay, both items still get power directly from the battery.
Old Jul 24, 2002 | 12:45 PM
Albertt's Avatar
Alls you're doing is >>
Making the foglamp relay get it's ON input signal from the hot of the parking lights INSTEAD of the headlight low beam. Don't worry about the fuses. Your foglights will pull the full 55Watts of power from the electrical system when they are told by the foglamp relay to do so.
Old Jul 24, 2002 | 12:50 PM
kenju4u's Avatar
great! thanks guys...I am gonna do this over the weekend.
Old Jul 24, 2002 | 01:00 PM
endus's Avatar
An atavistic endeavor...
Haven't had any problems with mine.
No. My understanding of it is that the sidemarker light wire just keeps the relay "on" so that the fogs can draw power whenever the sidemarker lights are on...the mod doesn't change where the power comes from.
and if it does wouldnt the foglights be not as bright as they would be in the original configuration? [/B]
No.
Old Sep 24, 2002 | 11:37 AM
maxima168's Avatar
problem
I did that mod and I keep blowing fuse(fog light fuse), I had higher wattage h3 headlight bulbs, then I returned it back to stock bulbs but I now keep blowing the taillight (parking light fuse).I have rewired the corner light also. I have upgraded the 7.5 taillight fuse to a 15. Is that safe? When I press on my brakes when I first get in the car my lights come on. I don’t know if my headlight go on but I think the fogs or something because my interior driving lights does. Also when im driving and I press on my brakes my radio gets all static.
Old Sep 24, 2002 | 11:59 AM
breaux124's Avatar
I sent you an email too.
If the upgraded fuse still blows out, then you have a problem somewhere. You might have grounded a wire somewhere. Make sure every wire that you cut it proper taped off (electrical tape ONLY) if not being used. Also, make sure that no wires have rubbed through and are exposed.
Double check all the connections and the splices that you made. I'm guessing something is getting shorted.
Old Sep 24, 2002 | 12:21 PM
maxima168's Avatar
thanks for the e-mail. im running a 15amp right now. but i dont think that is safe? is it? will how come my light come on when i press down on my brakes? this is with no key in the ingnotion. and my radio gets all static sometims.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
