Which factory horn is the "main" one?
Old Jul 24, 2002 | 09:33 PM
DigitalTexan2u's Avatar
I'm installing aftermarket horns tomorrow and needto find out which horn is the "main" horn, so I can wire that one to the relay?
Is it the one by the washer fluid tank, or the one out front by the radiator?
Thanks!!
Old Jul 24, 2002 | 09:43 PM
pocketrocket's Avatar
Re: Which factory horn is the "main" one?
We run dual horns. Both horns sound when you press the horn, otherwise you'll hear a crappy tone because you cannot get full range (lo-hi) with just one horn, you need two.
One horn is mounted inside the engine compartment (next to washer fluid tank) so it cannot be easily disconnected by reaching behind the bumper/grille. This is to help meet the anti-theft/alarm requirements.
Old Jul 24, 2002 | 10:14 PM
geo1317's Avatar
so which wire do u use to make sure you retain both the horn and the alarm?
Old Jul 25, 2002 | 05:21 AM
Albertt's Avatar
I think each horn has it's own relay >>
So I would think that it didn't matter which one you wired to the alarm.
Old Jul 25, 2002 | 08:53 AM
goldmax's Avatar
The one behind the grill is the main horn, the one under the hood is the alarm horn. Leave the alarm horn where it is and install your new horns in place of the one behind the grill. NOTE: There is an additional "dangling" wire with connector by the one horn behind the grill. You can use this to power your second horn. When you wire it up that way you will be using all three horns and have plenty of volume! It worked great on my Hella autobahn horns!
Old Aug 4, 2002 | 08:47 PM
Miasma's Avatar
sorry to bring up a semi old thread...
anyway, i am going to get the hella supertone twin horns, and want to know about which horn to replace.
this thread says two contradicting things:
1. one horn is high, one is low and they both sound for regular horn honking and alarm
2. one is for regular honking, one is for alarm
which is it and how should i best hook up the new horns, i think i would like to hide the new horns behind the grill if i can, but i dont know if the wiring will work there, or if they will fit. and regardless of which horn i replace, should i leave the other factory horn installed?
Old Aug 4, 2002 | 08:57 PM
geo1317's Avatar
well to finally resolve this, when i was installing my horns this past week i tested both leads for the horns and the only one that worked was the one in the front behind the grill.
so i hooked it up to that and now both my horn and ararm work through my air horns.
so use the lead for the front horn behind the grill.
Old Aug 4, 2002 | 10:02 PM
Miasma's Avatar
so does the horn by the washer fluid even do anything?
Old Aug 5, 2002 | 12:18 AM
geo1317's Avatar
not that i could figure, maybe the only time it worked was when the one befind the grill was pluged in. thats the only scenerio i didnt test
Old Aug 5, 2002 | 08:46 AM
95Max's Avatar
That is strange that only one works. BOTH of my horns honk. One is a low and the other a high tone. If it matters I have a 95GLE.
Old Aug 5, 2002 | 09:00 AM
Miasma's Avatar
interesting, i guess i will have to play around a bit
i will let you guys know
Old Aug 5, 2002 | 09:18 AM
ny96max's Avatar
pull out both horns, or else your airhorns and stock horns will sound at once and sound like crap!
you can get the relays input lead from the horn closest to the motor. As for the other horn just unplug it and tuck the wire away.
Ant
Old Aug 5, 2002 | 09:26 AM
Miasma's Avatar
'closest to the engine' do you mean by the radiator or by the washer fluid?
Old Aug 5, 2002 | 11:33 AM
nadir_s's Avatar
vicodin ... gift of life
I have a 96SE... I don't know about the other Maxima year/models but I'd have to say the nissan horn is a peice of crap! My brother set it off when the car was parked inside the garage and i could not hear the damn thing whne i was in the house...
Old Oct 12, 2002 | 04:51 PM
ddee06's Avatar
Does anyone have instructions on how to install the Supertone Horn Kit (with relay)? I purchased one from autosupermart.com part: 85315. I'm not sure if this is the one everyone else has purchased. I tried installing mine today without the relay and it didnt work Any help would be appreciated.
Old Oct 12, 2002 | 05:30 PM
geo1317's Avatar
check the 4th gen FAQ, i thinks its covered in there
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
