Trunk lock problem
Old Jul 27, 2002 | 09:19 AM
SonicDust187's Avatar
Trunk lock problem
I just wanted to know if my trunk lock is broken, because when ever I try to open the trunk with my key it doesnt even turn. Is my lock broken or on like a safety feature that doesnt allow me to use the key to open it?
Old Jul 27, 2002 | 10:09 AM
JdawgX's Avatar
You might try to lube it. Spray some lube into the key hole and then use your key to make sure it's in there front to back. Let it sit for a while and see what happens
You might also have a valet key, meaning that you can't open the trunk with it. Or the glove compartment. Try to open your glove compartment, or lock it. If you can't then you probably have a valet key
Old Jul 27, 2002 | 10:19 AM
I use the key that opens the doors, starts the car and opens and closes the glove compartment.
Old Jul 27, 2002 | 10:21 AM
JdawgX's Avatar
Then I would try and lube the mechanism.
Old Jul 27, 2002 | 10:26 AM
MaxJag's Avatar
Re: Trunk lock problem
Don't you have a button on your remote on your keychain to open it?
Old Jul 27, 2002 | 10:27 AM
Is there a way to take a trunk lock of another Maxima and make it work with my current key or will I need the key from that Maxima to open the trunk?
Old Jul 27, 2002 | 03:41 PM
JdawgX's Avatar
You'll need the key for the other Maxima to do that.
Old Jul 27, 2002 | 04:06 PM
purmax's Avatar
did you push the lock button that's inside the trunk? some kinda of safety thing
Old Jul 27, 2002 | 04:20 PM
JAY25's Avatar
I am having the same problem too I cant use my key to open the trunk I have to go and pull on the lever every single time. Ill lube it up and repost!!
Old Jul 27, 2002 | 04:42 PM
dedek's Avatar
Got the same problem...Will do the same ..
Old Jul 27, 2002 | 05:02 PM
skeelo34's Avatar
OMG speaking of trunk locks, shhhh. LIke 2 weeks ago, I sprayed my trunk with that foam stuff from home depot to kill bass rattle. WEll the foam oozed into the lock mechanism and made it solid. So now I can't use the key to get in, like i used to before. Whats worse is i flipped that little lever so i cant use the button. ****, i had to unscrew my box, take my seats out, somehow squeeze in into half a foot of space and flip the little lever and pry open the trunk. Not to mention that when the lock glued solit, I broke my key in it! I did manage to pop open the trunk, took off the whole lock assembly and fixed it. Man it was a nightmare.
Old Jul 27, 2002 | 05:17 PM
JAY25's Avatar
well I sprayed liquid wrench played with it for 10Mins and it seemed to somewhat fix the problem. I think from not using the key often seemed to have make the mechanism a bit hard to use. I rarely use my trunk anyways so that may be the problem. Ill try to use my key more often. But liquid wrench solved the problem quite a bit!!!
Old Jul 27, 2002 | 05:36 PM
badxl3oi's Avatar
i say the heck with the keyhole!!! hehe shave it and use go the good ol way and go handle everytime!!!
Old Jul 27, 2002 | 08:08 PM
nymjayjay's Avatar
just shave the lock like I did then you wont have problems
Old Jul 27, 2002 | 08:41 PM
Sprayed with WD40 and still no luck. Cant turn the lock. Is there a way to make my key work with another Maxs lock?
Old Jul 27, 2002 | 10:55 PM
max_speed97's Avatar
samething
i have the same problem also...cant use the key, always have to use the lever...funny thing is though that when i first bought the car the key worked at times and didnt...now it never works...i thought maybe had to do with alarm but dont know whats up
Old Jul 28, 2002 | 12:33 AM
nadir_s's Avatar
vicodin ... gift of life
I noticed the trunk latch on the Maxima's suck and seem so weak... make sure u don't slam it. My friend has a '97 and he had to get his replaced recently. Just watch out for that...
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
johnaschon
Sep 14, 2015 04:29 PM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
