ECU Codes 0104 0304 0504 0302
I've got a 95 SE with 106K miles. Recently I received the following ECU codes.
0104 vehicle speed sensor.
0304 Knock sensor.
0504 AT control unit or circuit fault.
0302 EGR insufficient or excessive flow detected.
My car is running rough at an idle, more noticeable when the car is in Drive than when in Park. The symptoms seem very similar to when I had a fuel injector go bad.
My questions are,
1. My speedometer is still functioning correctly, so can I assume my vehicle speed sensor is ok?
2. Where is the TCU (transmission control unit) located? I want to check the wiring between it and the ECU. From what I've read, this is one of the possible causes of 0504. Thanks DBM!
3. Bad battery is also a possible cause of 0504. Where is the power connection for the TCU? Is it one of the additional wires on the main Pos + cable connection to the battery?
4. How serious is 0302? The EGR's main purpose is to lower combustion temps to prevent NOx from forming. Can this lead to damage of the 02 sensors and/or catalytic convertor?
I'm not so much worried about the knock sensor 0304. My car is running rough and I not surprised it set 0304.
Thanks in advance for your help/advice.
-Pat
0304 Knock sensor.
My questions are,
-Pat
Re: ECU Codes 0104 0304 0504 0302
0304 Knock sensor.
My questions are,
-Pat
0304 Knock sensor.
My questions are,
-Pat
Originally posted by Miasma
how do you adjust the idle?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
