Got my DET running in my max and have a ?
How much vacum do most of you see at Idle mines around 10, Im curious cause my brakes seem really weak. also I should be hitting the dyno on the 10th of august at the nissan meet in PA so I will keep everyone posted.
I will have pics soon.
SC'ed with MEVI ,I'm at 16-17Hg
According to the Chilton's manual, spec is 17-22.
Although I've found most people get 22-24Hg.
And I'm losing 3PSI of boost somewhere!
I'm thinking you have a vacuum leak.
IanS
IanS
Re: Re: Re: Re: Compression Ratio
Originally posted by Black VQ
Nope, our VQ30DE is 10:1. The JDM VQ30DET has a 9:1 ratio so that it will work better with boost.
Originally posted by TILLEYS99
Im using Internals, heads and intake manifold.
The VQ30DET is out of a Y33 Cima (JDM Q45) and good luck finding one they arent too common.
-Jon
Originally posted by tmkforever
What are hp/tq specs on that engine? Where did you get it? How much $$? Sorry for all the questions...thanks!
-Jon
-Jon
NO its not for a FWD but I changed internals into my original block to make it work
Originally posted by Greg's2kGLE
What do you do about the engine fan? You are a real tropper to do an engine swap like that. I wish you the best of luck in the future.
Finally got Idle set and 20 inches of vacum. Put it this way it runs easily as good as it did with a 100hp shot of NOS and Im only running 8-9 psi. It also sounds awesome. It drives and sounds stock till about 3-3.5k then boost kicks in and you can here the whistle.
I'm interested in knowing if that might help my "problem".
IanS
How much did it cost you all together? seems like putting a RWD engine into a FWD would be alot of $$$$$$....how much was it all together with changing the internales and everthing? I would love to see what that car runs at the track since the other turbo max out there never runs his car
Oh yea... when's our bbq at your place
(of the engine itself and the engine in the car) Is that engine made for a FWD car?
