To All Who Bought Cattman/PlaceRacing CAI This Year---
Old Jul 28, 2002 | 07:48 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Does anyone else have major fitment issues with trying to get the MAF sensor section to fit into the intermediate intake tubing (clamped on silicone hose)???
I've tried:
-Lube
-Dumping the hose end into boiling hot water (in efforts to soften the hose compound).
-I finally resorted to slicing the inner hose tubing for extra flexibility to get the MAF tube to fit in.
Maybe it's the new silicone tubing PR/Cattman is using for their last batch of CAI but it's so STIFF that it's IMPOSSIBLE to get the MAF tube in.
Any suggestions? Tks.
Old Jul 28, 2002 | 07:52 PM
Vic's Avatar
Vic
Re: To All Who Bought Cattman/PlaceRacing CAI This Year---
and a lot of blood and sweat!
also tried prying the crap out of it with 2 screwdrivers.
I've installed 4 CAI's and this is the first time I got all this crap. I also noticed the rubber tubing is different from the previous ones. This one is much tighter and thinner than the older ones.
Vic
I've tried:
-Lube
Old Jul 28, 2002 | 08:11 PM
JDM4LIFE's Avatar
i went through the same problem installing the upper cai piece. it's cattman too. i did spray a lot of lubricant on it, completely loosened the clamps to the maximum, and had to move around the maf sensor piece a lot to get both ends to match up. good luck to you, i know your pain!!
Old Jul 28, 2002 | 09:30 PM
AsthmaMax11's Avatar
I've tried:
-Lube
Yes! Place Racing definately disapoints me for the over $200 I spent on it!
Old Jul 28, 2002 | 09:48 PM
mitch33x's Avatar
when I installed my PR upper piece (which I bought from Cattman) about a year ago I had no problems fitting it to the MAF
Old Jul 28, 2002 | 10:13 PM
MaximaPower's Avatar
ran into that same problem..my bro was in that last GD u had for the upper tube + filter combo....well it took me and my bro, with 2 flathead screwdrivers and about 20mins, to force the tube on the MAF
Old Jul 28, 2002 | 11:24 PM
CKNY's Avatar
mine doesn't really fit in correctly but i got mine last year.
Old Jul 29, 2002 | 12:18 AM
Nismo's Avatar
I had mine for less than a year and had no fittment problems at all. the connector/reducer hoses were a shiny black rubber fyi.
Old Jul 29, 2002 | 02:07 AM
sryth's Avatar
I noticed a snug fit, but nothing a little force didn't solve. My only problem came with the vacuum hoses. They didn't quite reach. I'll head out and pick up some new hoses, but aside from that, no problems.
I've tried:
-Lube
Old Jul 29, 2002 | 03:13 AM
carnal_c30's Avatar
Former Sponsor
I have an old prototype version didnt have any fitment problems with the MAF but the CAI piping is too short and it was finished in crappy fake silver before I repainted it metallic blue...
Old Jul 29, 2002 | 06:02 AM
97MaxGurl's Avatar
should I try to return the piece to Cattman... maybe he'll replace that silicone hose piece with one that'll give a lil.
Vic, Dee and I tried for over an hour using flatheads and everything that we could possible think of to get the MAF piece in but were unsucessful
Old Jul 29, 2002 | 06:30 AM
Confused's Avatar
Permanent Maxima.org Resident
Old Jul 29, 2002 | 08:36 AM
webboy's Avatar
I have/had no problems or fitment issues Just bought and installed 2 months ago from cattman...
Old Jul 29, 2002 | 07:07 PM
97MaxGurl's Avatar
mystery solved
Took a closer look at both ends of the upper tube and it looks to me like Cattman used the same size hose for both ends. That explains why we couldn't get the MAF tube in for the life of us.
That means one thing.. off to the post office tomorrow.
Old Jul 29, 2002 | 07:55 PM
mitch33x's Avatar
Re: mystery solved
Old Jul 29, 2002 | 09:42 PM
Mmmaxx's Avatar
hmm got mine like a month ago, still not installed although a friend was doing it and we got the upper piece on fine, then realized we didn't have the key to the tool box with the plasma cutter so its was pretty much just a "test" fitting heh seemed ok I hope I don't run into any problems when I do it all for real, god i wish I had the n00ts to mess around under the hood
Old Jul 29, 2002 | 10:14 PM
mblasko85's Avatar
mine was perfect!!! Although it was about 3 minuts of an effort to get it but not bad
Old Jul 30, 2002 | 03:09 PM
Vic's Avatar
Vic
It was fun having two gals spread while I pushed hard...
Vic
Old Jul 30, 2002 | 07:53 PM
97MaxGurl's Avatar
same hose diameter on both ends
The end that connects to the throttle body
Old Jul 30, 2002 | 07:54 PM
97MaxGurl's Avatar
the end that connects to the MAF section
Old Jul 30, 2002 | 09:14 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ange i can hook yuou up with a piece on coupler that will fit with mininal effort if you wnat just let me know.
Old Jul 31, 2002 | 08:42 AM
97MaxGurl's Avatar
thanks Stevie
Cattman messed up my groove.. now he's sending me the replacement coupler to fit my MAF section. I'll let you know what **** of it.
Old Jul 31, 2002 | 10:59 AM
jdmmax's Avatar
Re: the end that connects to the MAF section
hmmmm i have that end going to the throttle body and the other end is going to the MAF.
i used a little bit of motor oil just to lubricate the the silicon hose and then squeezed it in.
Old Aug 3, 2002 | 09:24 PM
sryth's Avatar
Re: Re: the end that connects to the MAF section
Same here. I used elbow grease instead of motor oil
worldwiderecognized
Sep 24, 2015 06:56 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Violator
Sep 9, 2015 10:14 AM
