Airbag light
Do a search..."airbag"
you set of a bump sensor...pot hole etc...
I think you turn the ignition on (don't start the engine)
reach over and push the BLACK BUTTON that is located in your drivers side door...it's the one that activates the interior lights when you get into your car.....push the button like 7 times and then shut the door and restart the car...try the SEARCH on this topic...I found the directions to this proceedure 3 months ago....
Re: Do a search..."airbag"
I had to reset my airbag light today too, kinda strange why it came on.
Locate the driver door switch, covered by the rubber grommet (it's located on the body, not the door) before you start the reset procedure.
Turn the key from OFF to IGN.
Within 7 seconds, push the driver door switch at least 5 times in 7 seconds.
Shut your door (or hold the switch in).
Start the car, then shut it off.
You should have successfully reset the warning light. If it comes on again, you could have a problem.
Funny how Nissan does this (putting different functions in wierd places)
hmmmm "how to unveil 50 hidden horsepower"
1. Turn ignition on
2. Press gas pedal 50 times
3. Open and close fuel door within 10 seconds
4. Insert audio cd into cd player, wait 10 seconds
5. Turn key to off position
6. Poof 240 hp for following precise directions
1. Turn ignition on
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
