Blown fuses
Old Jul 29, 2002 | 09:42 PM
NATE98GLE's Avatar
Blown fuses
Is there an easy way to check to see if there are any blown fuses, behind the fuse panel in the car. I'm not sure if a blown fuse might be causing my battery and brake light to flicker on and off. My mechanic said its not my alternator. Or if resetting my ECU would fix the problem.
Old Jul 29, 2002 | 09:46 PM
97BLKMAXSE's Avatar
i dont think its a fuse problem. my guess would be the wiring somewhere.
Old Jul 29, 2002 | 09:48 PM
NATE98GLE's Avatar
I put indiglo gauges in months ago. Do you think it could be caused by that?
Old Jul 29, 2002 | 09:50 PM
97BLKMAXSE's Avatar
my guess what have to say mabye you might want to try to take it out and check the wiring, and go from there.
Old Aug 1, 2002 | 02:54 PM
eskim_77's Avatar
It happened to my car today. While it was raining, I saw those two light come up, and never goes off. I restarted the engine, same problem. What's wrong with this? Mine is 97 and 64K miles, and I can't believe this thing happen to me today..
Old Aug 1, 2002 | 04:49 PM
NATE98GLE's Avatar
Originally posted by eskim_77
It happened to my car today. While it was raining, I saw those two light come up, and never goes off. I restarted the engine, same problem. What's wrong with this? Mine is 97 and 64K miles, and I can't believe this thing happen to me today..It is your alternator.....after dealing with these lights for a few weeks, my car finlly died. Get your car checked ASAP.
Old Aug 5, 2002 | 06:29 PM
eskim_77's Avatar
Originally posted by NATE98GLE
Did your light goes on whenever it's raining? After I test Voltage reading, its output was normal. 13V while engine off, 15V while engine run with AC, Defrost...It's weird. Light only comes on whenever it's raining.
leatherneck
Sep 30, 2015 09:16 PM
homewrecker
Sep 24, 2015 07:01 PM
conansriver
Sep 16, 2015 12:17 PM
Maxie40
Sep 14, 2015 11:28 AM
