Humming noise while driving?????
Old Jul 30, 2002 | 09:23 PM
97GXE's Avatar
Got a 97 GXE, Automatic. When driving, a humming noise comes from the front. I hear it at 10 mph. At around 40 its still there but other car noises dampen it.
-Noise the same dispite surface of the road.
-Noise the same if I put the car in neutral while driving (Trying to eliminate the transmission).
-Noise the same after I rotated the tires.
Kinda sounds like the noise my rear drive ford mustang use to make. Then, the rear axle needed fluid.
Any ideas???
Old Jul 30, 2002 | 10:55 PM
jcy98maxse's Avatar
Turbo is too much fun!
Re: Humming noise while driving?????
Any ideas???
it may be a wheel barring. My hummed a little when it was at slow speeds and turning
Old Jul 31, 2002 | 05:41 AM
njmaxseltd's Avatar
Sounds like a wheel bearing. Does it get louder if you go around a left or right sweeping turn? If it gets louder on left sweepers, then it's your right bearings and Vs-Versa.
Old Jul 31, 2002 | 07:49 AM
breaux124's Avatar
I have the same issue, but it's coming from the rear. Are these hard to change? Do we replace it, or just repack and regrease it?
Old Jul 31, 2002 | 08:51 AM
97GXE's Avatar
Thanks! I'll test it out
Old Jul 31, 2002 | 09:10 AM
MaxKlinger's Avatar
I would agree that it sounds like a wheel bearing. I had my left front one go, and it used to sound like a pulsating hum that would change with speed. That and a temp sensor have been pretty much the only things to ever go wrong with the car over the course of 153k miles, knock on wood!
Does anyone else notice a low, quiet whistling noise that changes with speed? I think it's coming from the transmission - I find it most noticible between 30 and 45 MPH when in overdrive (Automatic). I'm not concerned, it's been making that noise since it was new, just curious what it is.
Old Jul 31, 2002 | 09:13 AM
Shift's Avatar
it can possibably be the belt is either to dry. try putting some belt dressing on it and the pullys. if you still hear the hummmmmmmm it mostlikly one of the bearings are going out on either the waterpump, alternator a/c compressor.
but check to make sure the belt is in good condition w/o any cracks in it. look for the cheapest diagnostics first.
good luck!
Old Jul 31, 2002 | 10:43 AM
black019's Avatar
wheel bearing. i had this same problem but just got it fixed last weekend. its kinda expensive to get fixed unless its covered under warranty.
Old Jul 31, 2002 | 10:51 AM
breaux124's Avatar
I've read the fronts are hard, but what about the rear?
Anyone have a clue how much the parts cost for the rear?
Old Jul 31, 2002 | 11:10 AM
95emeraldgxe's Avatar
alternator might be dying
Old Aug 27, 2002 | 05:41 PM
ypl102's Avatar
got the same problem, but I like the sound, makes it sound more like my SOHC 3.2CL-type S. My experience is the pitch of the noise increases with RPM, just like the sound u'd hear from a tweeter out of a stereo system with engine radiation noise, but perhaps less noticeable. I then pinpointed the fact the noise is coming from fan outlets. If I turn off the fan and de-select any blowing modes, the noise disappeared. For now I can tolerate it being there.
Old Aug 27, 2002 | 07:31 PM
ypl102's Avatar
what I meant was the whirring noise the original poster mentioned, not the bearing noise from the front axles.
Old Mar 25, 2008 | 12:19 PM
hungtdao's Avatar
My 1999 Maxima gets squeezing noise while driving but the noise stops when applying brake. I have changed brake pads 3 years ago without noise until recently. I checked brake pads. They are only 2/3 worn, the alert metal part has yet touched the rotor. Does anyone know the problem? Thanks
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxie40
Sep 14, 2015 11:28 AM
