HELP WITH STARTER!!!!!
Old Dec 12, 2000 | 09:28 AM
My starter just die on me last night. I guess it lasted pretty long. I have almost 130k miles on my 96 max now.
where is the best place i can get a starter?? and how easy is the installation?? planning to install it myself.
I found several starter on carparts.com but they have different starter. some with a solenoid and some don't which should I get??? and is those price preety good??
Manufacturer: ORANGE COUNTY ALT * Prices are quoted in U.S Currency.
Description glossary Part Number List Price Your Price Core Price Qty Add to Cart
STARTER W/SOLENOID-REM, 8 Tooth Drive; Early 17695 $302.11 $181.27 $50.00
Manufacturer: BECK ARNLEY * Prices are quoted in U.S Currency.
STARTER-REMAN, 8 Tooth Drive Gear 187-0614 $267.45 $163.35 $82.00
Manufacturer: BOSCH * Prices are quoted in U.S Currency.
STARTER W/SOLENOID-REM, Hitachi SR2268X $355.50 $266.60 $75.00
STARTER-REMAN, SR2268X $355.50 $266.60 $75.00
Old Dec 12, 2000 | 09:48 AM
Daniel B. Martin's Avatar
I found several starter on carparts.com but they have different starter. some with a solenoid and some don't which should I get??? and is those price preety good?? ... ...
It is advisable to buy a rebuilt starter with a warranty. A starter obtained from an auto recycler is already worn, and might not be much better than the one you've already got.
Remanufactured units are available for $140 (Brand X) up to $360 (Bosch).
If done by a shop the labor charge ought to be one hour.
This is a job which can be done by the home mechanic.
No need to jack the car, the starter motor is accessed from above.
1. Disconnect the cable from the negative terminal of the battery.
2. Remove the air intake duct and the air cleaner housing assembly.
3. Disconnect the battery cable and the solenoid terminal connection from the starter solenoid.
4. Remove the starter motor mounting bolts and remove the starter from the engine. These bolts may be really tight!
Old Dec 12, 2000 | 11:15 AM
where on the net for me to get a good starter???
Should i get used(refurbused? or new??
Old Dec 12, 2000 | 11:33 AM
I've been pleased with my experience with on-line purchase from PartsAmerica.com. Go to http://www.partsamerica.com/
I've placed two orders with them and got 100% "fill" (no backorders) and really fast turnaround. In my case, I elected to pick up my orders at the nearest Advance Auto store. With this deal, there was no charge for shipping and no sales tax. (I wonder how they get away with that?!?)
I believe that a properly remanufactured unit is every bit as good as new. You might want to do a price comparison with a new starter from your nearest Nissan dealer. You could also contact one of the dealers which sells Nissan factory parts at discount.
Steve Cutchen has an excellent MaxFAQs page:
http://web2.airmail.net/scutchen/max_faq/
It cites two Nissan dealers who sell factory parts at a discount.
Brown and Brown Nissan, Tempe AZ.
Parts department: 800.237.0003
http://www.brownandbrowntempe.com/parts_form.cgi
Courtesy Nissan, Richardson, TX.
Parts department: 800.527.1909
http://www.courtesyparts.com/
When you contact them be sure to mention you got their name from the Nissan newsgroup.
Old Dec 12, 2000 | 12:18 PM
expenisive$340 from nissan
that's pretty expensive. i might get the one from carparts.com. but do i need the one with the SOLENOID???
Old Dec 12, 2000 | 01:36 PM
Re: expenisive$340 from nissan
I don't know if the solenoid on your installed starter is good or bad. If you don't know either, play it safe and get one with the solenoid. [I thought all rebuilt starters came with a solenoid.]
Old Dec 12, 2000 | 01:41 PM
rocket_slave
My starter died on me last week. It's not too hard to pull, follow the instructions above. Once the starter is out, it's simple to disassemble. I found that my brushes were very short. I cleaned all the muck out and went to an alternator and starter shop specializing in foreign parts. The shop guy yanked the old brushes, put in new ones, and I was out the door in 15 minutes and only $15 lighter. It's worked perfectly since.
You might need a new solenoid as well. In that case you'll need to compare having a shop rework your old one vs. buying a remanufactured unit.
Old Dec 12, 2000 | 02:24 PM
... ...and how easy is the installation?? planning to install it myself.
See http://vbxmaxima.8m.com/starter.html
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
