Rubbing sound/sensation felt while coming to a stop
1 of few unmodded 4G Maxs
Lately I've been noticing that when I come to a stop, not only can I hear some rubbing noise but I can feel it for a few pulses just before coming to a dead stop, I don't know if it's coming from the brakes or the tires but somewhere up front, and I am aware my tires are a bit worn and seems like something either in the brakes or whatever is rubbing against something else, any suggestions? btw the car does not have ABS
Re: Rubbing sound/sensation felt while coming to a stop
Add a third to the list. I have this sensation too. I've had it since I bought my car (used). The front brakes were serviced before I took delivery on the car and the rear pads are plenty good still. It is intermittent in my case, but more prominant when it is warm out. Doesn't bother me much anymore. but I would like to fix the problem if possible.
i've got the same thing. new brakes too! guy at meineke told me some brakes just make that noise when pads press against the rotors. maybe they just need to break in a little? i'm nervous because i have a torn cv boot so that could add to my problem. hopefully noises are perfectly normal and will go away.
I have the same problem, except that this only started happening the last time I got my tires rotated. So, in my case, I do not think that it is a problem with my rotors. Does anyone have any other ideas?
i have the same problem too with my 95 , i do not brake hard and when i do brake (always soft ) i had the same noise, sometimes the noise would go away but then it would come back , its worse when its wet out, i had my rotors and brakes checked to see what the problem is and the mechanic told me they were both new and that maybe its just the brand of brake pads thats causing that , but he said its not gauranteed, prob a nissian defect?
same here!!!!!!!!!
does ANYONE KNOW WHATS WRONG???
I just bought a 99 with new brake pads, rotors seem fine and not warped, the cv boots dont look torn but they keep making a juddering noise everytime I brake. first it was on one side, now it's on both and it's getting louder with each day....any ideas?????
Check your wheel lugs. Make sure you didn't overtighten them. That can cause rotor warping (I'm told), which causes wierd noises
This happens on my car sometimes, but it is not the brakes. I just put new rotors and pads all the way around, and it still happens sometimes. I am leaning towards tire noise on my car, but it could be a wheel bearing too.
sctludwig
09-01-2022 01:32 PM
