manual transmition fluid change
Old Aug 4, 2002 | 12:22 PM
apocnmbr1
Im changing my transmition fluid on a 95 5 spd., and i have 2 questions..would you guys go with the REDLINE MTL or The AMSOIL...ive heard good about both but i am sort of leaning towards the redline....Second How many quarts do i need for the change?? I wa reading about a miata and he had to use 2.5 quarts...YIKES!!! HOW MANY AM I GONNA HAVE TO USE!!!
Old Aug 4, 2002 | 01:38 PM
iwannabmw's Avatar
Re: manual transmition fluid change
Obviously, I say Amsoil, but if you do go with Redline, the MT-90 is better suited for the Maxima.
You should buy 5 qts to make sure you have enough. The transmission holds 4.5.
Old Aug 5, 2002 | 01:35 PM
apocnmbr1
u guys would take the MT-90 over the MTL?? ive heard a lot better things about the MTL...also u think i should go with amsoil?? Damn...now im really confused. I thought that the majority said to go with redline....any more opinions??
Old Aug 5, 2002 | 02:29 PM
Ramius83
Mine only held 3 quarts.....?.....
Old Aug 5, 2002 | 02:58 PM
BlkStnValyMaxima's Avatar
It must not have been completely drained when you filled it.
Old Aug 5, 2002 | 03:28 PM
iwannabmw's Avatar
Which hole did you drain it out of??
Old Aug 5, 2002 | 03:39 PM
iwannabmw's Avatar
Most people here do use Redline, but I've managed to show some the light with Amsoil. I prefer Amsoil not only because I'm a dealer, but I've used Redline in the past and don't see why anyone should pay the price difference for it.
In the interest of staying objective, the reason I said MT-90 instead of MTL is that the MTL is a much lighter weight, so while it will shift much easier in cold weather than the MT-90, it won't protect anywhere near as well when the transmission is warm. MTL is around an 80wt oil when warm, while the MT-90 is a full 75W-90, more inline with Nissan's specs. Since these transmissions are a weak link in this car, I would prefer to have the better protection of the MT-90 than MTL. Of course there is Amsoil 80W-90 in my car right now.
captchaos
Mar 15, 2016 12:18 PM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
flu2000
Sep 8, 2015 02:23 PM
