do i need a new clutch??
Old Aug 4, 2002 | 06:12 PM
SlowJoeMax's Avatar
my max is the first 5 spd that i have owned, and i dont know too much about the clutch and the problems that goes on when i need to replace it... it seems lately that when i put it in first gear it takes a fw seconds when i am releasing the clutch for it to go into gear, it didnt use to take as long, now when i start off it jerks some what cuz its not catching as fast, is this just my driving or should i b looking to buy a new clutch in the near future?
Old Aug 4, 2002 | 06:33 PM
MAXINXS's Avatar
Re: do i need a new clutch??
It sounds like you are not giving the car enough gas when your letting the clutch out or your letting the clutch out too fast if it jerks (bogs). Try revving the engine slightly higher and slowly let out the clutch as you give it a little more gas. You would know for sure if your clutch was slipping. The rpm's will climb and the car will only gradually speed up. Similiar to spinning the tires on ice. My clutch used to slip when I shifted fast. Good luck.
Old Aug 4, 2002 | 08:15 PM
95emeraldgxe's Avatar
sounds like your clutch is slipping, but then again it might be what maxin said
Old Aug 5, 2002 | 01:19 PM
az_maxima's Avatar
slipping
If the clutch is slipping it will be more apparant in the higher gears. Try this: Lug the car in 5th (~40mph), push in the clutch, wind it up to about 5k and dump the clutch. It should grab relatively quickly. If not, time to replace.
Old Aug 10, 2002 | 07:59 PM
SlowJoeMax's Avatar
Re: slipping
thanks i will try this tomorrow and let you know what happens
Old Aug 11, 2002 | 08:38 PM
SlowJoeMax's Avatar
Re: slipping
well i did exactly what u said and the engine just seemed to rev backdown to about 2000 rpms, so that means i need a new clutch, right?
Old Aug 11, 2002 | 11:38 PM
_DRU_'s Avatar
Re: Re: slipping
no, if it catches on right away, that means its not slipping. It seems like ur not giving enough gas when you take off like maxinxs said. try giving it more gas and riding the clutch more to get a different feel.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
