making automatic windows (1 touch) ?
Old Aug 6, 2002 | 01:46 PM
GaMax97GLE's Avatar
I have 97 GLE with a driver's side 1 touch automatic window down button. I want to make the passenger side window do the same thing. These are the options I was thinking of doing, which will work best, if at all:
1) Buy another button just like the driver button and put it in the space for the passenger button in the driver side console (but will the passenger side control be 1 touch)
2) buy 1 touch module and install it on the passenger side window (but will it be 1 touch from the drivers control's too?)
I hope this makes some sense, anyone with ideas please let me know.
Thanks,
Eric.
Old Aug 6, 2002 | 02:25 PM
FLO_BOY's Avatar
Re: making automatic windows (1 touch) ?
Thanks,
Eric.
I think the "one-touch" resides in the switch...not the motor.
Also, I'm not sure if each switch is independant...anyway, my $0.02.
FLO_BOY
Old Aug 6, 2002 | 02:38 PM
97BLKMAXSE's Avatar
try this place. i was thinking of doing that to my sunroof.
http://www.autoloc.com/detail.lasso?itemid=WC1000
Old Aug 6, 2002 | 02:41 PM
myiqis180's Avatar
Re: Re: making automatic windows (1 touch) ?
FLO_BOY
I opened up the whole control module on the driver's door. The one touch thing, is on the actuall circuitry (like the little moder-board). You cannot just get a botton and place it there. The way it works is: Your auto switch can send two different signal, one to tell the motor to go down until you release (which is the first stop), and another signal (the second stop) which actually send a signal to the controling circuit which in turn send the signal to the motor until the window is all the way down. If you just add another boton, there's nothing to interprete the second signal, and it just wont work. In comes the aftermarket module.
Old Aug 6, 2002 | 02:42 PM
climaxima's Avatar
or you can always get the smartwindows module that you use with your clifford alarm. 1-tough up and down on both front windows and control through your alarm remote. really nice in the summer to be able to open the windows from 100 yards away and let it air out a little. just a suggestion.
Old Aug 7, 2002 | 11:31 AM
GaMax97GLE's Avatar
Re: Re: Re: making automatic windows (1 touch) ?
So if I buy the Autoloc module and insatll it between the passenger switch and the motor that will make the passenger side switch be 1 touch, but can I use the driver side switch to controll the passenger window and it be 1 touch too? Thanks.
Old Aug 7, 2002 | 11:45 AM
Max4Speed's Avatar
www.autotalk.com
Ditto! thats what i got
Old Aug 7, 2002 | 12:04 PM
GaMax97GLE's Avatar
How much extra dpes it cost?
Does it have to be done at installation or can it be added afterwards?
Old Aug 7, 2002 | 12:12 PM
Max4Speed's Avatar
www.autotalk.com
I added mine afterwards..
Old Aug 7, 2002 | 12:14 PM
climaxima's Avatar
I had mine done with the rest of the alarm. I am actually going to get it set up on the back window also here.
Old Aug 7, 2002 | 12:17 PM
Max4Speed's Avatar
www.autotalk.com
Yes mine are for all 4 windows. I wanted to do on the sunroof too but it was a B***h to work on so i opted out!
Old Aug 7, 2002 | 01:00 PM
GaMax97GLE's Avatar
So the inside buttons are all 1 touch AND you can control the windows from your alarm?
Old Aug 7, 2002 | 01:09 PM
TurDz's Avatar
I remember when I rented a 5th Gen 2k1 it came with one-touch driver/passenger side windows.
Old Aug 7, 2002 | 05:02 PM
meccanoble's Avatar
Sports Button FTW
yo, both my front windows can go up and down at a button, and they can go up and down even when the key is taken out provided u press the button before taking out the key...how did i get to this situation.....
i had alarm which controlled all windows, i can roll up and down whenever alarm is put on or off....then back modules died and changed alarm but i guess guy kept the modules working. Well now, for some reason, even when power of car is off, i can STILL roll up the windows as long as i started before i took key out....pretty cool ehh?
works great when the day is hot, u pull up to park, u put gear in neutral, pull parking brake up, press the up button, take out key, let door unlock, step out, walk a quarter the way down the street and see your windows just FULLY rolling up....definitely stops from wasting precious time...
Old Aug 7, 2002 | 06:51 PM
ny96max's Avatar
DEI makes a window module that will act as either a 3/4/5 channel off your DEI alarm depending wich model(viper/python/clifford/Avital) you have installed already.
The actual unit at cost will be around $60 or $150-$170 regular price
...and NO i dont have these installed yet cause my alarm brain will not accept more than 3 channels. So now i need a channel expander($30 cost direct from DEI)
Ant
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
