Wet Window Problem
Old Aug 11, 2002 | 04:57 AM
MaxJag's Avatar
Wet Window Problem
After washing my car and drying it off, if I roll my windows down and back up they get covered with water drops. Then the sun dries them up and it leaves water marks. I've dried them off up to four times after rolling them down and back up but the water comes back as if theres a big pool of water inside my door. Is this normal or is it only happening to me? Maybe I need to replace the bottom rubber windonw seals. What do you members think?
Thanks in advance
13 More Days and I'm outta Kuwait and back in the U.S of A. in the Max!!!
Old Aug 11, 2002 | 07:39 AM
kmax's Avatar
It happens to me also. I keep them closed until everything in the door dries.
Old Aug 11, 2002 | 08:35 AM
outkastist's Avatar
this is normal...i think it is water on the seal that makes your window look like that...just dont open your windows for a while you'll be fine
Old Aug 11, 2002 | 09:20 AM
95emeraldgxe's Avatar
its normal - dont roll down your windows for 2 hours
Old Aug 11, 2002 | 01:21 PM
Sin's Avatar
Sin
Re: Wet Window Problem
Thanks in advance
What I do is use my finger nails to pull the seal away from the window just enough to slip a clean shop towel or paper towel into the gap, and dry it off. This also removes a TONNE of dirt and dust btw, and allows you to now open the windows right away.
Old Aug 12, 2002 | 05:05 AM
MaxJag's Avatar
Re: Re: Wet Window Problem
Thanks for the tip. I'll try this next time I give it a washing.
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
