What should I do? CEL on again, blinking & more!
Old Aug 12, 2002 | 06:28 PM
JR_Anders's Avatar
About a week ago my CEL came on, I checked it and it threw code 0505 "No Failure Recorded/Detected". I reset it and drove on happy On Saturday I washed my car & engine bay (Simple Green & water) I covered up all electrics but not the knock sensor (didn't know what this was). Then yesterday my CEL light came on again and I got code 02 15 "Undefined", and 03 04 "knock sensor". I reset the light and my CEL blinked when I started it, I heard this means the engine is misfiring I got code 03 04 again. I just reset the CEL and will see what happens, it did not come back on or flash this time. The engine seems to be running fine and I think I feel a little lag in performance, may just be in my head from reading about knock sensors all day! So what should I do now? Buy a new knock sensor and replace it, purchase a Volt meter to test it (aren't these expensive?), or just see if the CEL comes on again? Sorry for the long post!
Old Aug 12, 2002 | 07:18 PM
MIXXMAX's Avatar
Re: What should I do? CEL on again, blinking & more!
I would just keep checking if the knock sensor comes up on its own (no CEL, but the 0304 code). If it does, I would recommend replacing it. Not too hard to replace if you have small hands and tough skin.
Old Aug 12, 2002 | 07:29 PM
JR_Anders's Avatar
I'll check again tomorrow. Do you know if the CEL flashes it means the engine is misfiring
Old Aug 12, 2002 | 08:26 PM
MIXXMAX's Avatar
I believe ONLY if it continues to flash while you are actually driving the car. I have'nt actually heard any cases of Max's having their CEL blink or flash under normal driving conditions. I know one time, when I tried to reset my computer one time, the CEL flashed a few times upon start up, but then it went away and never did it again. Maybe, the computer was "self-adjusting" ? This happened to me last year, and I never had any major problems because of it. I meant to ask a Nissan mechanic about this, but it always slipped my mind. Again, I would only start to worry only if the CEL flashes/blinks WHILE driving. Then, something is DEFINITELY going wrong with the car that needs attending to!
Old Aug 12, 2002 | 08:40 PM
rmb's Avatar
rmb
The CEL blinking is a major fault, misfiring could be one cause since that would cook your catalytic in a hurry. There's a bunch of "bad" codes that would make it blink while driving. Excessive lean mixtures too since you could melt holes in the pistons..... Excessive knock would also trip it(or a faulty sensor thinking it was knock) which would retard the timing to be on the safe side.
I'd just replace the knock sensor if I were you.
Fun stuff
-RMB
Old Aug 12, 2002 | 08:47 PM
JR_Anders's Avatar
It only flashed that 1 time after I got the code and reset the ECU, it went away a second after I started the car, I didn't drive at all.
Old Aug 13, 2002 | 03:39 PM
JDM4LIFE's Avatar
i would just check out the knock sensor and see what's up with it. do a few tests to see if all the terminals check out fine (tip: don't go pushing tips of voltmeters inside terminals, it can mess them up and you'll definitely need a new one). hopefully, it'll be a faulty knock sensor, becuz if your car is knocking.... yikes. btw, unless it flashes while driving down the road, don't worry much.
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
JoshG
51
Sep 21, 2015 10:41 PM
BrandonCause
Sep 14, 2015 10:41 PM
dcardello
Sep 3, 2015 11:44 PM
