best brake kit to get????
Old Aug 14, 2002 | 04:02 PM
RI-Max's Avatar
hey guys i need new brakes pretty soon and i was just wondering whats the best pads to get and where??? and which rotors are better slotted or drilled? i wanna go as big as i can with my stock wheels. cause i have stock rotor/pads and i can't stop for crap!!
thanx
Old Aug 15, 2002 | 06:38 AM
RI-Max's Avatar
bump!!!! i need them soon help guys!!!!!
Old Aug 15, 2002 | 07:05 AM
njmaxseltd's Avatar
Get the Stillen x-drilled rotors with Metal Axis pads all the way around. A great upgrade from stock for just over 400 bucks.
Old Aug 15, 2002 | 09:14 AM
RI-Max's Avatar
anyone have the brembo setup???? on their max???
Old Aug 15, 2002 | 09:40 AM
tmkforever's Avatar
I just replaced my OEM pads with Porterfield R4-S pads. They are really great pads. I haven't had any problems so far. They stop my car quickly and with little pedal travel. There is no shake or wobble and there is hardly any fade. I've only got OEM calipers and rotors and these pads really shine. In the future I hope to upgrade to some sort of big brake kit, or at least new rotors and maybe new SS brake lines. njmaxseltd, you sound pretty happy with those Stillen rotors. Weren't they made from Brembo blanks, too?
Old Aug 15, 2002 | 09:49 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
just get oem rotors with some raybestos quiet stops.. the pads are ceramic and silent. Don't worry about crossdrilled and slotted unless you plan on doing some extreme braking. Sure they cool a little bit better, but all rotors warp.
Old Aug 15, 2002 | 10:25 AM
max_speed97's Avatar
porterfield r4s
i also put these on last week and have had no problems...stops well also
Old Aug 15, 2002 | 10:27 AM
njmaxseltd's Avatar
Yes they are Brembo blanks modified by Stillen. There Zinc plated as well which cleans up the hub really nicely. They'll never rust! I've heard from others on this board that they don't warp either. I hope I have the same good service others have had with them. I had my OEM rotors cut 2x in 50K miles. Thats enough BS for me, it was time to change them.
Old Aug 15, 2002 | 10:59 AM
turbomax97's Avatar
all rotors will warp eventually...... even stealin's. It just depends on the driving style. If you don't believe me, find someone with brembos, brake hard and heat up the rotors then splash some water. I'll bet my car that it will warp.
Same goes for x drilled and slotted, they will warp too. It's just a matter of time.
Old Aug 15, 2002 | 11:21 AM
jerzeeMax's Avatar
How long do the ceramics last compared to oem? Are they harsher on the rotors or about the same?
Old Aug 15, 2002 | 12:02 PM
njmaxseltd's Avatar
Explain to me why my 330 doesn't warp rotors?
OR
My buddies 98 I30 with 100K miles on it, has had perfectly smooth brakes from day 1, original Nissan/Infiniti Equipment.
OR
My 89 Prelude SI with over 170,000 miles on it when I sold it never once warped the rotors.....
OR
My Yamaha FJ1200 with 52,000 miles on it which has perfectly smooth brakes, and that baby has seen some intense high speed braking.
Shall I go on???
Old Aug 15, 2002 | 12:58 PM
turbomax97's Avatar
well you must be good on the brakes, who knows.. the way the brake system is..... especially with the FWD cars are, they are prone to warping. Not to mention that warping can be unnoticable to bad enough to shake the steering wheel and pulse the pedal. Do this with your 330 if you think it's discs are exempt from this. Do some hard braking getting off the highway, then pull the ebrake. Or go wash your wheels. I can go on and on. I'm partly biased because I'm from TX where it's hot as hell and rotors take much longer to cool. The brake shop where my mechanic works pretty much routinely has to either turn or replace rotors from the warping.
Btw, the ceramic raybestos have a lifetime warrenty @ my pep boys.
Old Aug 16, 2002 | 01:48 PM
RI-Max's Avatar
my rotors are not warp yet (factory)and i drive pretty hard and i just hate when i hit them and they don't stop cause their all hot and stuff. sso im thinging about get the autozone rotors for 27.00 front and 26.00 for the rear. and the Porterfield R4-s pads where can i get a good deal on these??? and are low on nosie and dust??? and how long would this setup last me????
thanx jeff
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
