Do you guys warm up your engine in the morning?
Old Aug 14, 2002 | 08:55 PM
dedek's Avatar
I normally warm it up about 2-3 minutes until the temperature raise a bit. And in the winter time, it takes about 5 minutes.
I read on a 99 ITR manual that it doesn't need to be warm up because they said that it will waste gasoline. and I couldn't find anything about it on Maxima manual.
What do you guys think?
Old Aug 14, 2002 | 09:06 PM
invaderr's Avatar
Re: Do you guys warm up your engine in the morning?
I ussually wait till the rpm's are lower than 1000
Old Aug 14, 2002 | 09:11 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
You shouldn't let the car idle more than 1 minute, summertime or wintertime. It is better to drive off slowly than let the car idle for a long time because the engine will build higher oil pressure- which helps circulate the oil better- plus the engine will warm up much faster when you drive it. Don't rev the motor quickly (zing the motor) and rev too high for a first few minutes after driving off.
Old Aug 14, 2002 | 09:21 PM
ny96max's Avatar
i let mine sit for about a min or two just to get the oil pressure up, then im out!
Ant
Old Aug 14, 2002 | 10:04 PM
clee130's Avatar
Read and enjoy:
http://forums.maxima.org/showthread....arming+morning
Old Aug 14, 2002 | 10:25 PM
nadir_s's Avatar
vicodin ... gift of life
Originally posted by clee130
Read and enjoy:
whaaaaaaaaaa
damn thanks for the link! Time to change an old habit
Old Aug 15, 2002 | 01:10 AM
dedek's Avatar
Read and enjoy:
Thanks...
I searched before I put this new thread but I couldn't find it at 4th Gen forum..
It was a really good thread.
Old Aug 15, 2002 | 01:43 AM
Nismo's Avatar
about an minute then I just drive it, keeping the rpms low until the temp as at least off the cold mark
Old Aug 15, 2002 | 03:45 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Same here.
Old Aug 15, 2002 | 06:23 AM
pblaze's Avatar
Originally posted by dedek
Do you guys warm up your engine in the morning?..
There's no need to warm up your car before driving it. You should drive it gently until it does warm up though. I usually use very light throttle and keep the RPM under 3000 until about 5 minutes after the coolant temp gauge reaches normal. What you really want is for the oil temp to come up before you horse the engine.
Old Aug 15, 2002 | 07:32 AM
njmaxseltd's Avatar
Re: Re: Do you guys warm up your engine in the morning?
Exactly!
Old Aug 15, 2002 | 08:02 AM
02SM520's Avatar
First thing.. I start up the car..
Second.. put CD in / hook up the Handphone to
Hand free machanism.. (It takes 1 or 2 min)
and I just drive off..
So summer (1 to 2 min)
winter (3 to 5 min)
Old Aug 15, 2002 | 08:36 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Even though my max is garaged most of the time, I still run it for a few minutes before I need to go anywhere
Old Aug 15, 2002 | 08:52 AM
nadir_s's Avatar
read the link ppl!
Old Aug 15, 2002 | 09:28 AM
tomj's Avatar
Driving around to warm up the car and shifting around 2500 rpms is how I do it. That way the other important thing gets warmed up too - tranny.
Old Aug 15, 2002 | 09:31 AM
meccanoble's Avatar
Sports Button FTW
you're not supposed to let it sit, just drive and don't go over 3k rpm until your car is heated a little over the C on the temp gauge
Old Aug 15, 2002 | 12:40 PM
95seMax's Avatar
i let my car warm up for about 5 min in the winter or untill the rpms reach under 100 then i drive slow untill the cars temp is normal in the middle, in the summer i do the same thing maybe about a min, is it necessaRY FOR U TO WARM THE CAR IN THE SUMMER
Old Aug 15, 2002 | 04:23 PM
Nismo3112's Avatar
Custom User Title
NISMO....LMFAO @ ur sig pic!!!!!
Old Aug 15, 2002 | 09:00 PM
AsthmaMax11's Avatar
i usually just slap it in neutral and floor the gas until i see smoke coming out the tailpipe....then im ready for the day.
Old Aug 15, 2002 | 10:02 PM
Nismo3112's Avatar
Custom User Title
well...sounds like it COULD work
kjlouis
Nov 24, 2018 06:09 AM
conansriver
Sep 3, 2015 06:38 AM
maxipower
Aug 21, 2015 11:10 AM
Balkins
Aug 12, 2015 06:39 AM
