VI install in NYC area?
Has anyone here installed the VI and willing to help me install it? They would be compensated. I want to get the VI but I don't think I'd be able to install it myself. I want the install to be quick and clean.
Re: VI install in NYC area?
It's not that difficult, really. Just a little time consuming.
IanS
Re: Re: VI install in NYC area?
I would feel safer if someone who has done it did it for me. or at least helped me. I've never taken on something of this size. I've installed intakes and small things like this. But if I screw this one up, I won't have us of my car. That would be bad.
ZuM
ZuM
Originally posted by iansw
Get a chilton's manual and read Section 3-17.
IanS
IanS
It's pretty hard to screw something up. Theo nly real danger is dropping something down inside your engine after taking the manifold off.
To remedy this, just stuff each port with a towel or rag to keep dust and screws from getting in your engine.
If you do that, the chance of screwing something up is 0.
IanS
IanS
And hooking up the vaccum canister and mounting everything is a snap? If so, I'll jump right in and be the next guy with VI. =)
ZuM
ZuM
IanS
IanS
Yes, the vacuum system is easy as long as you understand this:
1)Buy a good vacuum canister
2)The solenoid is activated by the relay connecting it to ground (it has constant power, but no ground when dis-activated)
3)The RPM switch should be hoked up to a coil wire (the multi-colored one), and set to 'Coil per Cylinder', NOT '6 Cylinders'
IanS
IanS
IanS
IanS
You can buy one anywhere.
NAPA has one that has a check valve built in...it looks like this:
Vacuum Tank NAPA part #730-1607 ~$12.00
(Thanks to MardisGrasMax for the Pic and PN)
Originally posted by 96sleeper
I already bought this vacuum tank but I am wondering, which is the in and which is the out? The two ports are different sizes, so I am not sure which is which. Thanks for the help.
MaxLife17
Jun 27, 2019 01:37 PM
