Will someone please help me diagnose this infernal engine light
Old Aug 16, 2002 | 11:27 PM
jerzeeMax's Avatar
My CEL threw a code for the TPS like 4-5 months ago, but I reset it and it never came back until recently, where the light was up constantly. Since then acceleration has been crap along with the trans. In the meantime I got a Frankencar midpipe and threw that in, but while I was installing it I disconnected the air temp sensor (the thing that was plugged into that plastic ram air piece) and forgot to plug it back in when I started the car. This set off a few more codes - one for the knock sensor, one undefined, and one for the AATS, obviously because I forgot to plug it back in - but when I did the KS and the 0409 stayed, along with the TPS code (even after resetting). I replaced the TPS a couple weeks ago, which took care of that - even though throttle response and shifting improved a little, the engine was still very sluggish. I thought the TPS might have been triggering the KS and the 0409, so I held off on getting a new KS. But after I installed the TPS and reset the ECU, those two codes came right back the next day minus the TPS code. So fine, I replaced the KS and the car seriously felt like new after I reset the ECU again -for about 30 miles, but then the CEL lit up again, still 0409. As of now it still drives much better, but what am I supposed to do with this undefined CEL?
btw I also bolted on a Greddy SP before I got a new TPS. Had some problems w/ the 02 sensor rattling on the heat shield, but I banged it in a little to get some clearance and I haven't heard any noise from there since.
Old Aug 17, 2002 | 01:10 AM
maximavr6
re
my check engine light is on how do i check ti see whats wrong
Old Aug 17, 2002 | 06:04 AM
mzmtg's Avatar
Minister of Silly Walks
Re: re
http://forums.maxima.org/showthread.php?threadid=104931
Old Aug 24, 2002 | 12:52 PM
jerzeeMax's Avatar
bumping.
No one has seen the 0409 CEL before?
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
