question bout drop and camber kits
Old Aug 22, 2002 | 03:46 PM
aznsap's Avatar
if i were to drop and go get an alignment... would a camber kit be needed? im kinda confused about what they're for, liek the stillen camber kits i've seen on eBay and such. thanks.
Old Aug 22, 2002 | 03:51 PM
Aaron's Avatar
Langley AFB Sux
Re: question bout drop and camber kits
Im not sure if im lucky but i just put sprints on....just about a 2 inch drop. I took my car in and had a 4 wheel alignment done.... im at -1 degree camber (negative camber he said) basically i think that means the wheels tilt one degree in towards the car.... 0 camber would be straight up.....in relation to the axis.....im no suspension guru...as you can read....but for a 2 inch drop the guys were shocked that they could get it close to specs....... 1 degree negative camber is good for cornering tho......
I think any lower and you would need the eibach camber bolts....or the stillen camber plates....the plates offer a broader range of adjustment....more for the autoX group.....
Hope i havent confused the doo doo out of you
Aaron
Old Aug 22, 2002 | 04:09 PM
MaxedOut's Avatar
I dropped my car and my camber was WAYYY off.. i was about -3.75 and -.2.75
so i bought the eibach camber kit... it helps..
just drop it and see... someimtes u would need it soemtimes u wont..
Old Aug 22, 2002 | 05:08 PM
aznsap's Avatar
o i c..... so if i drop my car, and go in and get an alignment.... if my camber is way off, then i have to buy a kit? for some reason i thought alignment would fix these things for you, but they just give you measurements?
Old Aug 22, 2002 | 10:49 PM
Aaron's Avatar
Langley AFB Sux
Yes the alignment should....you should be fine as long as you dont go any lower than 2 inches.
Aaron
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
