Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
I just installed a used aluminized mandrel Warpspeed y-pipe that came off Jran's car...he's selling his Max soon.
Anyway, my mechanic installed it and when I start the car it has a nice lil purr...cool..
But, when I accelerate (even a lil) at any speed, there's this annoying buzzing sound that comes from the pipe that sounds like angry bees! I thought...I bought a warpspeed so I wouldn't have this problem.. Anyway, what do you guys think could be causing this...is there any way I can get that annoying buzzing to go away? I hate to accelerate cuz it sounds like I have a civic w/exhaust!
Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
Title quote:
It could be two things:
Flex section is causing the noise, or there is a severe leak coming from the mounting flanges (bad gaskets).
Re: Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
Originally posted by Smooth Operator
Title quote:
So is it new or used?
Title quote:
How would I be able to tell if the flex secton is causing it? I took my car to a muffler shop and they looked at the exhaust and they said it was alright, there was just a little gap between the cat and b-pipe that they welded together for $30..but the annoying noise is still there!
Re: Re: Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
My bad..well it's new to me...but yeah it's a used pipe.
Btw can you elaborate on the "little gap"? was this pre-existing?
Yeah take it back to the mechanic.
Re: Re: Re: Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
Get under the car and hold a tube next to your ear on one end and point the other end at the flex section and the y-pipe to cat mounting flange, etc. Did you use new gaskets?
When I took it to the muffler shop to check things out, the guy said when I put the y-pipe on it did not fit exactly right, causing the cat and b-pipe to be offset a little bit where they connnect, causing a small gap where the screw wouldn't go in all the way to tighten it. So he said he'd weld it together, and he did for $30. I thought this would fix it, but no, it's something else.
What could it be? I don't think the mechanic could help me out if the muffler shop thought everything was alright.
Re: Re: Re: Re: Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
I'm almost positive you have a leak somewhere. My flex section has never buzzed and I have the same pipe as you. I'm not sure how your mechanic just looked at the gasket and said it was good because both of my stock cat gaskets looked fine to me, but both leaked after i installed my y/greddy. Just have someone rev the car up while ur under it (use jackstands) If you have a leak you'll feel it.....
Originally posted by Jamsan
somewhat off-topic, but i too am getting the same exact pipe used from someone, and its coming on monday....where can i get new gaskets for it?
A word of advice, don't even try to loosen the cat nuts without first heating them for about five minutes each with a propane torch. I rounded one off with a 6 point socket, and it took me quite a while to cut it off. Good luck.
Leaking flex section. My first Y-pipe was a Warpspeed and it had a hole within the flex section. But that was a long time ago in their first generation Y-pipes. Since this is used, it's possible it is one of those older pipes. For around $50 you can get a new "lined" flex section from them.
Originally posted by pblaze
Bring it back and have them take a look. On my '98 there was a bracket that bolted the cat's to the block right near the oil pan. The Y-pipe runs righ along side it. Make sure it's removed, or bent out of the way.
also, the gaskets are metal crush gaskets; not suggested for reuse.
Simple leak test. After the exhaust system is COMPLETELY cold, start the car, lie on you back, and put your hand up close to the flanges for the cat and y-pipe and flex section. You should feel hot air blowing on you hand if you have a leak. Another problem might be that the shop reused the manifold to y-pipe crush ring gaskets which is a no-no. This could make the exhaust VERY loud. With a cold engine, the car supported on jack stands, take you hand and feel around the manifold to Y-pipe flanges.
It takes a good couple on minutes for the exhaust to warm up at idle so you have plenty of time to survey the flanges without getting burned.
Dave
Dave
Re: Re: Re: Re: Re: Re: Installed New Warpspeed Y-Pipe...Sounds Horrible Tho...Help!
$100 - Used Alum Mandrel Warpspeed Y-Pipe
$70 - Original y-pipe installation
$30 - To weld cat/b-pipe together since the y-pipe flange didn't fit right
$60 - To weld the leak in the y-pipe
$260!!! That's $15 away from a new SS Warpspeed y-pipe...course I would have had to pay shipping and install...but still!
Moral of the story: don't buy a used part until you have inspected it carefully or just buy a new one!
lrb6805
Sep 17, 2015 04:49 PM
