For all you smart car guys
Old Aug 23, 2002 | 08:15 AM
96BLUMAX's Avatar
I had an new engine put in recently and everything was goin good until I had to get it smog tested. It failed twice. I had some Nissan people look at it and they said it was due to a misfire at a certain rpm. The code that came off for that for primary ignition signal fault. A pretty big code so I am taking it back to the people who installed the engine. I was just wondering if anyone knew about a problem like this and what might be hooked up wrong to cause this? Any help would ease my mind. Thanks.
Old Aug 23, 2002 | 08:17 AM
Ramius83
Most likely, it sounds like a harness is either unplugged, or a harness has been cut/damaged, preventing it from giving the ECU the proper readings.....
Old Aug 23, 2002 | 08:21 AM
njmaxseltd's Avatar
Check your condensor. The primary ignition side is the low voltage side. Something as simple as a connection thats not secure can screw that up.
Old Aug 23, 2002 | 08:39 AM
96BLUMAX's Avatar
And with that problem it would cause my car to misfire?
Old Aug 23, 2002 | 08:50 AM
njmaxseltd's Avatar
YES
Make sure your ground wires are all secure as well. Not the battery terminals, I'm talking about the various ground pionts on the engine.
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Balkins
Aug 12, 2015 06:39 AM
yat70458
Aug 3, 2015 01:16 PM
