help with check engine light diagnostics
Old Aug 23, 2002 | 10:44 AM
myamin's Avatar
Hi -
My 95 Maxima GLE had the check engine light on right before noon and then in about five minutes it went dead on me in the middle of the street. I was able to get it back on after a while and to a parking lot. The codes are 1 3, "Engine Coolant Temperature Sensor" and 3 4, "Knock Sensor". I understand the knock sensor issue but any info on the 1 3 code???
Thanks,
M.
Old Aug 23, 2002 | 10:48 AM
s2cmpugh's Avatar
try clearing the codes out again and see what happens. if it comes back, pull the codes. if its the same 2 codes than you need to replace both sensors, however i would do the Knock Sensor first b/c i here that can pull up ghost codes
hope this helps
Cris
Old Aug 23, 2002 | 11:14 AM
myamin's Avatar
hope this helps
Cris
Thanks. I removed the codes and drove to work (5 miles) from the Gas station. It hasn't come back yet. But I remember them about a month ago with the exception of car engine going dead this time.
Thanks again,
M.
Old Aug 23, 2002 | 12:41 PM
njmaxseltd's Avatar
Don't change the knock sensor first!
If you get the engine coolant temp code again, change that sensor. If your cars ECU can't read the temperature of your engine, it may have a hard time adjusting the air fuel mixture and can make your car run to lean or to rich causing excessive ping, thus triggering the KS code. (hows that for a long sentance)
In this example the KS code is the ghost code. It's triggered by something else.
If after fixing the engine temp sensor, the KS code comes back, then replace it.
Old Aug 23, 2002 | 12:47 PM
dashingMax's Avatar
Do you think that an oxygen sensor code for the B-pipe ( P0420 ) can throw the Knock Sensor code ( P0325 )?
Thx
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
